05-18-2014 | #21 |
Re: testing the ALCL. poor cold start running
Do you have air in the line?
What's your static pressure? Does it drop off quickly after priming?
05-18-2014 | #22 |
05-18-2014 | #23 |
I put the pressure gauge on my Malibu and it held 30psi.
Also the gauge will hold 23psi with the ignition on and turned off after the car has started. I replaced the clamps with metal ones, all 6, and ignition on it jumps to 23psi, and the same when starting the car/idle. It holds pressure when I turn off the car. I am pretty sure its the pumps. They are old and just before all this I rode around on reserve twice waiting to get gas since I was going to Indiana (i'm about 5 miles from the border, maybe less). Do the suburban pumps drop in without any issues?
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 05-18-2014 at 05:44 PM. |
05-19-2014 | #24 | |
05-19-2014 | #25 |
One last questions, are the strainers for this car available? If so anyone know the part number or an equal replacement part and or number?
Is it necessary to replace the strainers? I never have and I have changed plenty of fuel pumps. Thanks!
05-19-2014 | #26 |
For me, I would always change them out. Over time, they start to plug up making the pumps work harder. You can sometimes see this with filters collapsing in the middle.
05-23-2014 | #27 |
New fuel pumps arrived last night and will be going in tomorrow!
05-23-2014 | #28 |
Did you ever do a static pressure test?
If you have leaking injectors, new pumps won't make any difference. Getting a new bike pump won't patch a hole in the tire... I think you should do static pressure, and then chart leakdown time.
05-23-2014 | #29 |
Static pressure test?
With the ignition key on and the car not running the fuel pressure guage will hold 23psi and not move. Is this what you are referring to? I posted other test results in this thread too.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 05-23-2014 at 03:20 PM. |
05-25-2014 | #30 |
New fuel pumps and strainers are in and i'm back on the road. No more bog in second gear either.
