Old 12-13-2016   #21
Default Re: Stereo Upgrade Options
Only if you have C60 will it definitely be an issue
Old 12-13-2016   #22
2ljd
Thanks for the info!
I have the C68...some of the posts I had looked over said it was the C68 that required the resistors.
2ljd is offline   Reply With Quote
Old 12-13-2016   #23
TSB attacted
Old 12-13-2016   #24
2ljd
Cool, thanks!
Hopefully I don't have to use it, but good to have just in case.
Old 12-14-2016   #25
cvette98pacecar
Try without any resistor first. I installed Alpine unit in my 91 back in 92 and installed Pioneer Avic Z140BH in 2012. Both time I did not use any resistor and no issue.
I have now done radios in 5 C4 I have not had any issue's where I needed to install resistors. All head Units are Avic 140 or 150BH.
Old 12-14-2016   #26
george1945
Just recently bought a 90 ZR1 for my wife. Picked it up in Michigan. Went directly to Heibecks shop for injectors and a through service and check. Decided since the Boise system was needing repairs, and the car is not a collectors piece, I would upgrade. For not a lot of cash you can repair the speaker amps, put in a new technology head with auxiliary Inputs, CD/DVD, backup camera and navigation. It is so clean it looks like it came that way.Problem solved. Will put the old unit on the shelf for now. Problem solved
george1945 is offline   Reply With Quote
Old 12-14-2016   #27
george1945
Forgot the blue tooth etc etc etc.
