Old 06-02-2014   #21
yzpilot
Default Re: Tackleing the big job before summer!!
Ok guys...stage 1 complete! I am really happy how it turned out! What do you all think?? At the risk of this turning to a technical post...since I got it back together it idles a little funny. Shoots up to 2 grand on start up..which I know is sometimes normal..but when it comes down it seems to bounce between 900 and about 1200. Kind of annoying. It didn't do this before. Just purred steady. Also when I come to a stop it stays higher, about 1500?? Any ideas? Thanks guys!!
Erik
________________________
1991 #422
Blk/Blk
yzpilot is offline   Reply With Quote
Old 06-02-2014   #22
Looks great.. You may need to check for a vacuum leak or the IAC. Just a guess I'm sure the guys in the know will post up.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-02-2014   #23
Pete
Pete's Avatar
Did you disassemble/reassemble the TB?
Sounds like vacuum leak but check TPS is set correctly.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-02-2014   #24
Pete
Agree w Pete. Check TPS, AND possibly Min Air Adjustment. Helpful if you have a scan tool. If you disassembled the TB, then he you need to have the throttle blades aligned.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-02-2014   #25
yzpilot
Ok, at the suggestion of a good friend, I took off the air boot and (choked it) with a book. Within 2 seconds it died right out. Didn't hear any hissing from vacuum leaks. Pretty much went through a can of carb cleaner over the top end, and got no change in rpm at all. Pulled the IAC and checked for cleanliness, reinstalled. Seemed to idle normal at first then rose back up to a high idle. Checked the TPS setting and was good. Even adjusted a bit but idle only rose, so set back to original position. Guess a plenum pull is in order!:-( What a bummer!
Erik
1991 #422
Blk/Blk
Old 06-03-2014   #26
DID U DISASSEMBLE THE THROTTLE BODY WHEN YOU POWDERCOATED?
Old 06-03-2014   #27
yzpilot
I did. Whats the procedure for aligning the throttle blades? I try anything before pulling the plenum again!
Erik
1991 #422
Blk/Blk
Old 06-03-2014   #28
Pull off the throttle body and send it to Haibeck.
Old 06-03-2014   #29
Schrade
Get a sheet of gasket material, and cut out one of these.
If your TB is leaking by 2nd butterflies, then with this in place, idle will hold steady as a rock, and the lope will disappear.
Old 06-03-2014   #30
yzpilot
Schrade, are you using this in place of the stock gasket?
Erik
1991 #422
Blk/Blk
