#21 | |
![]() Join Date: Feb 2014
Are you sure you aren't looking at later resonators? My understanding was that GM opened the resonator up A LOT in the 93-95 cars, but that the 90-92 resonators were the primary bottleneck, as they closed down to about 1-5/8" diameter. I had thought that removing the resonator from an early car would make a worthwhile difference. Is that not the case? Thanks! |
#22 | |
![]() Join Date: Jun 2005
Anyway, the only experience I have which is similar was the Record Run car from way back in the day. It ran with stock manifolds but otherwise open exhaust and it had an aftermarket calibration to optimize the air fuel ratio for that. You'll have a little more restriction than that but you're removing 2/3s to 3/4s of the restriction by cutting off the resonator and the mufflers. I think it's possible you may need to richen up the motor at WOT, but...check with Marc. My guess is he knows if you need to or not. The main reason I suggest that is most people these days are running on E10 gas. The 6-7% ethanol usually in oxygenated fuel requires a more rich AFR to begin with–at WOT it goes from 12.5:1 down to about 12.2:1. So right there you're already lean. When you get rid of the restriction of the resonator and mufflers, the engine will go a bit lean and, if you never had the cal redone for E10, then you might end up too lean. Again, check with Mark. |
#23 |
![]() Join Date: Feb 2011
x-piping the stock exhaust will induce a little resonance at 1700-1900 rpm, but much much less than just slapping a full 3" system on a vette. If you keep the stock mufflers, they still do a good job at keeping things reasonable plus the pipe diameter, bends, and pipe thickness is otherwise unaltered and part of the original engineered quiet system.
I was happy to run around like that for a year until I got greedy and did headers etc. Something I have never tried, but would be interested in seeing how it worked out: ... those compact glass-pack tube sections in place of the resonator with otherwise stock pipes. Maybe a little quieter compared to and H or X-pipe? |
#24 |
Thanks again, Hib. I really do like it loud and I loved my L98 on cats alone (albeit 3 of them) but consensus seems to be that the LT5 on only 2 cats will make a lot more noise than that. Like "race car" loud, which may be OK for me but not for passengers or the local constabulary. I think I'm going to swap the resonator for an x-pipe first and then drive it for a little while before I go hacking off the mufflers. Easier to take more off than to put some back on, I guess!
#25 |
Also I had loud-azz borlas on an LT1 C4 before with totally stock everything else...very loud and droned in the hatchback badly. The mufflers do all the heavy lifting.
#26 | |
#27 | |
Thanks! Chris |
#28 | |
I can offer some instructions on how to build a great exhaust system for a ZR-1. It's the system I've had on my car for about 15 years. See this web page. |
#29 |
![]() Join Date: Jul 2005
On my '91, I have a '94 ZR-1 exhaust system with stock '94 resonator and the stock '91 cats. I cut the mufflers off the '94 system, welded in straight pipes and fabbed up '91-like tips.
It has great sound, but doesn't resonate at cruise. It also picked up 9 rwhp and 19 ft/lb at the wheels.
Constantine Registry Founding Member #0235 1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete. 1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car. https://www.youtube.com/watch?v=z8y4cwcvK0s 1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car. 1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything. |
#30 |
![]() Join Date: Jan 2004
My system got good "sound" comments after I built it some time ago.
Watson headers and 3 inch pipe 3" cats 3" x "18 straight thru bullet mufflers in the tunnel leaving room for an x pipe in front of it. Flowmaster 40s at the the rear with straight tips. My next system will add the blended X pipe. I want to dump the Flowmasters and just put straight thru bullet mufflers out back. If I really get carried away I can put another lenth of bullet muffler after the turn past the differential. I could also use the tips that also have the sound deadening perforated interior section in them. In spite of how short they are they do seem to have a noise reduction factor to them. That should give it a tone so low you will think its a big block. This would essentially make it a straight shot once past the cats.
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black Last edited by ZRXMAX; 04-21-2014 at 11:51 PM. |
