Old 04-07-2014   #21
Default Re: My last effort
Originally Posted by Mitsumark View Post
As stated in previous threads..Vette Docs..Car was built in 2003..Yes..Car is burning about 1/2 qt in a couple hundred miles according to dipstick and smoke.Injectors are brand new FIC stainless units..Oil/Crankcase has absolutely no smell of fuel at all.However it could be totally thinned out as the car was running all winter in 20dg weather and a ton of warmup/idle time..I may do a Castrol.Syntec 20/50 oil change and see what I get..I doubt that's the answer though..
Gold-Car had 200+ compression in every slug..Still possible rings?
Im thinking its the valve seals. how many miles on the motor since rebuild ?
Yep motor needs to come out. easiest way since timing has to be reset etc
Old 04-07-2014   #22
Mitsumark
Just replied to you in the for sale section..If you give me a couple days,I could dig up the receipt with the specs..When I bought mine just recently,,the fronts are readily available on EBay..Same exact ones for Trans Am/Camaro..The rears I had custom made from ARE as ZR1 offsets were discontinued long ago and no supplier anywhere had left over stock...They made my rears for $300 each..
Mitsumark is offline   Reply With Quote
Old 04-07-2014   #23
Z06scentair
Z06scentair's Avatar
Thank you.
What kind of advice have you gotten from Marc or Arron on the oil consumption?
Z06scentair is offline   Reply With Quote
Old 04-07-2014   #24
Mitsumark
Haven't spoken to either of them on consumption..Only spoken to Marc on tuning issues...I think it's safe to assume that constant tailpipe smoke is not normal..
Old 04-07-2014   #25
Z06scentair
Not normal for sure....something bad wrong? Not convinced, I'm leaning heavily on the side of valve seals.
Old 04-07-2014   #26
Blue Flame Restorations
Almost sounds like it has too much pressure and can't breathe.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-07-2014   #27
Z06scentair
That's a possibility... but why two cylinders would be oiling the plugs has me corn-fused
Old 04-07-2014   #28
Mitsumark
As far as I'm concerned if the the motor needs to come out,,that's bad..If I were to have it pulled,believe me it would get torn down and fully rebuilt..I did speak to Marc on rebuilding as a worse case scenario..He wants 9K to fully rebuild to 368 specs..That's even using my liners and rods..Then another $800 to dyno tune it..Then whatever other problems he may find..On top of that its probably gonna cost an additional $1500 to get it there,return home,then back again to get it..I love the car..But not that much...
To much pressure,can't breath?..What kind of pressure?..here's my take..It can't be too much fuel..Car has no gas in crankcase,starts easily...Car has strong compression and plenty of pulling power,no blowby from oil cap or dipstick..Rings seem good..Only thing left is PCV which I triple checked for obstruction in every tube..Non found..That only leaves valve seals...
Old 04-07-2014   #29
Are they next to each other? What modification had been to this motor is anything?
Old 04-07-2014   #30
Z06scentair
Im certainly no LT5 expert but a broken ring or big problem would be causing drivability issues one would think.
It may be worth your while to call SGC and see what they recommend.
