Old 04-15-2014   #21
carter200
carter200's Avatar
Default Finished designing and machining the Billet single/double throttle cable clip
I have fixed the issue with the billet throttle cable clamp. Thanks for your understanding, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 04-16-2014   #22
carter200
carter200's Avatar
Default Re: Finished designing and machining the Billet single throttle cable clip
The fun keeps coming. I just saw a pick of a 91 plenum and the throttle cable clamp pads do NOT look like my 95 plenum pads. Here is the 91:
My 95 only has one threaded hole in the the center of each pad. Can anyone else verify how your pad is configured and the year of your plenum so I can get this squared away. Thanks in advance, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 04-16-2014   #23
Exactly as your photo shows for 90' and 91'
Old 04-16-2014   #24
carter200
carter200's Avatar
Cliff,
I just checked into pics of plenums and the 90 - 92 have the dimple pad with threaded hole and the 93 - 95 have the single threaded hole in the pad. Now I see why the ones I sent out had an issue as they were all early dimple style.
I guess I'll have to make two style ones. Hope all is well with you. Later, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 04-17-2014   #25
tccrab
tccrab's Avatar
Pic of Girlfriends plenum showing hole and dimple on back pad.
'Crabs
Old 04-24-2014   #26
Meanmyz
Meanmyz's Avatar
I just want to mention this for what it is worth. The stock '92 clips are different from the '93 to '95 clips. (I don't know about the plenum pad being any different from '92 to '95).
Anyway, the '92 clip was wider than the '93-'95 and the hole in the clip was oblong so that there could be some adjustment. I do not know if the '93-'95 clip will work on a '92 plenum...I am guessing that they are the same pad.
So, there were actually three stock cable clip styles offered, '90-'91; '92; and '93-'95.
Meanmyz is offline   Reply With Quote
Old 04-24-2014   #27
LantanaTX
Excellent work! I need a double set for a '91
LantanaTX is offline   Reply With Quote
Old 06-30-2014   #28
Just opened up a box from Carter.......including the Throttle Cable Clips for a 90'
Perfect in every way....thanks
Cliff
Box contained......
1. Set Throttle Cable Billet Brackets.
2. One Fuel Line Billet Clamp (87 and 91 in red).
3. Two Brake Reservoir Tops.
4. One Oil Filter Cover with Etching AMSOIL 10W-40.
5. Coolant Reservoir Top.
6. Coolant Overflow Top.
7. Power Steering Reservoir Top.
8. Winshield Wiper Reservoir Top.
9. TB Top polished Billet Aluminum with Chev and LT-5.
Including the Hood Stop and TB Coolant Plug.
All Etched appropriately
Old 09-01-2020   #29
Perry Mitchell
Are the cable clamps still available? I need a pair of the double type for a '91. I also need one additional clamp for a modified feature on my car for a total of three double clamps. Thanks, Perry
Last edited by Perry Mitchell; 09-01-2020 at 01:42 PM. Reason: spelling correction
Perry Mitchell is offline   Reply With Quote
Old 09-01-2020   #30
carter200
carter200's Avatar
Perry,
PM me and we'll get you taken care of
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
