#21 |
![]() Join Date: Feb 2011
Here's what the shims look like when not installed above the spring bushing. my car was slammed and the two aluminum shims are shown here going along for the ride (at least they didn't toss them).
#22 |
![]() Join Date: Oct 2004
I checked two springs I have here, a '91 removed at 16K from a ZR-1 with the "green ink" and a code of FHA with the molded pad as in Mike's image. I have another from a '93 that is assembled with the riveted on metal reinforcement and the 1 1/4" square pedestal cushion like I believe all '92+ cars are assembled with and they both have the same FHA code. That tells me the spring rate is the same and if there are differences in any of the publicized specifications then the assembly procedure at the control arm ends is responsible for that variance.
Mike - What are the actual codes stamped/molded/branded in your two springs? The code can be checked from underneath easily, it should be maybe 2 - 4" inboard of the control arm contact area. |
#23 |
I'm away from my car until the end of the week, but I do remember the stamped code matching from one spring to the other when Erik(YZpilot) and I swapped.
#24 |
![]() Join Date: Aug 2006
WVZR-1,
'91 @ C is 177mm and a '94 @ C is 192mm" Am I understanding correct that end of spring rubber pad (90-91) vs. later cars w/ puck results in later cars sitting 15mm (about 9/16") taller? |
#25 | |
The math substantiates your deduction. If though the '92+ spring is assembled with the "puck" then that would seem to negate that thought because the '92 FSM mentions the 177mm @ C. There's no doubt that it's somewhat confusing. |
#26 |
Yes. It is very confusing.
#27 | |
![]() Join Date: Oct 2013
Mike,can you post a photo of the bushing shims you're referring to in the above post? Last edited by USAZR1; 05-19-2014 at 01:20 AM. |
#28 | |
#29 |
the two shims are actually shown in the last photo I posted. they are riding under the bracket and sandwiched together. They are supposed to be on top of the spring- at least the PO didn't throw them out. they are just flat aluminum stock- You could make replacements easily. On the previous page, one is also shown next to the blue floorjack wheel on that pic.
#30 | ||
![]() Join Date: Jun 2005
"WVZR-1", if you're aware of any incorrect information in that article, so I can correct any mistakes, please post the errors and your documentation to support them. But even if I was paid for it–let me ask you "WVZR-1"–in your opinion, how would that impact the credibility of the content? Quote:
The spring suppliers were required to categorize each spring which met the initial specifications into three groups. Some were right at the specified spring rate, some were a bit below and some were a tiny bit above. The spring group determined the number of shims (ft.) or the location of the shims (rr). This system allowed the assembly plant to have all the cars much closer in trim height and was used for the rest of the C4 production. Obviously, in the front, the ideal sitch is a car with 2 shims because pulling the shims out lowers the car by about 1/2-in.. In the rear a car with 2 shims above the rear spring is desireable because if you move the shims to below the spring you lower it in the rear by about 1/2-in. |
