01-15-2014 | #21 |
Re: Long cranking
Agree ,with the reluctor setup on a DOHC the engine has to find the reference at cam and crank and it probably checks it....
Also an engine were they were worried about cam seizure on cold start up(thanks to a BG employee starting then at full throttle), alittle pre-oiling is probably build in....does not hurt to get the pressure up before it fires.
01-15-2014 | #22 |
Re: Long cranking
It startles you when it fires instantly upon turning the key, but it does happen from time to time. I always like it better when the engine cranks for a few seconds so it can get oil up top.
01-15-2014 | #23 | |
Re: Long cranking
ed.: Brett beat me to the punch here; immediate startup, when #1 'fire' happens to be in 'X' position in rotation???
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 01-15-2014 at 02:05 PM. |
01-15-2014 | #24 |
Re: Long cranking
I thought there was a four second delay to firing up.
01-15-2014 | #25 |
Re: Long cranking
Mine also starts instantly when hot, I wonder if it looks at a percentage of oil pressure and temp also. And if it is just before the sensors signal the ECM.
01-15-2014 | #26 |
Re: Long cranking
Mine generally only does it upon the first start of the day....when it happens, which is only now and then. I generally start the car every day just to keep oil up top.
01-15-2014 | #27 |
Re: Long cranking
I don't start mine every day, but when I do start it I also let the pumps run a bit before I turn it the rest of the way to crank it. I had to do that on my BBC in my Nova or it would stumble bad when started and sometimes backfire thru the Carb.... So I kinda got used to doing it...
Mine cranks for 3 or 4 seconds as well.
01-15-2014 | #28 |
Re: Long cranking
Speaking of oil pressure at start up, anyone
ever use an Accusump? Where would you plumb it in? Where would you put the sump/accumulator? |
01-18-2014 | #29 |
Re: Long cranking
01-18-2014 | #30 | |
Dual Oil Filters
I was working on a Billet Aluminum Remote Oil Filter Adapter a while back and had it sized to fit under passenger side headlight (I think I was relocating the coolant overflow). The Design was for Dual Oil Filters. I was working on a System that would NOT Drain Back but still easy to change filters without a mess. That Remote Oil Filter Adapter I Designed fit in place of the present Oil Filter. Had SS Braided Oil Lines going down to the Billet Aluminum Remote Dual Oil Filter Housing Adapter. Now that I think of it......I think I left the Coolant Overflow in place and positioned the Remote Oil Filter Housing Adapter where my Secondary Pump was previously located (Since Removed).........Or......moved existing Coolant Overflow Tank where Vacuum Pump was located and positioned Billet Dual Oil Filter Housing Adapter in place of Coolant Overflow Tank. I have the specs Oil Filter Adapter fits on existing Oil Filter Housing Dual Oil Filter Housing Adapter fits in area under Passenger Headlight
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-19-2014 at 02:00 AM. |
