12-03-2013 | #21 |
Re: Installed No Flex Frame Stiffener Bar System
I really think these should have been a part of the ZR-1 package. The motor has so much HP that hammering the throttle twists the frame and causes the positraction to react further amplifying the problem. I believe this sets in motion a back and forth momentum in the chassis that prevents low speed hookup. Once the car finally dampens this motion it then can really start to roll. JMHO,
Tyler
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White |
12-03-2013 | #22 | |
12-03-2013 | #23 | |
Maybe time for some new rubber Discount Tire FRONT.................................................. ....................REAR Nitto NT 555 Extreme Performance..................................Nitto NT 555R Drag Radial P275/40ZR-17 98W.................................................. ...315/35R-17 102V B .................................................
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-03-2013 at 07:00 PM. |
12-03-2013 | #24 |
Fairly new rubber, two years old, but new found power. Ported plenum and IH.
12-03-2013 | #25 | |
Tyler
12-03-2013 | #26 |
Tyler,
So you think these would help the ZR "bite" better at the track? And w more power, getting it to the ground gets more problematic. Is that why the ZR appears to accelerate stronger in the second half of the 1/4?
12-05-2013 | #27 | |
Tyler
12-08-2013 | #28 |
Jeff,
With your black ZR-1 the mounting bolts show up. You could just paint them black ,or install 49th street rockers to hide the front and rear mounting bolts. I drag race my Zr-1 and my 60ft. times avg. 1.73 to 1.78 , 1/4 mile times avg 11.65 to 11.72 @ 118- 120 mph. I might have to look into frame stiffener bar system. John Becker 1990 white/black # 2546 one of a few auto (4l80E ) eq. ZR-1's |
12-08-2013 | #29 |
Yeah, I have the rockers waiting to get painted
12-26-2013 | #30 |
I ordered the no flex frame stiffener for my 1990 auto eq. zr-1 on Dec.
17. 2013. installation was completed on the 21 of Dec on a 4 post lift.It took a little longer then what the instructions said. Front brackets took about 20 mins to install. The rear brackets took a bit longer because i have DRM c4 trailing arm brackets installed. the lower dog leg had to be moved to gain access to the lower trailing arm bracket bolt. After installing the rear frame stiffener bracket and bolt, torque the assembly to 80 lbs. The lower dog leg was reinstalled and ride height checked. Without adjusting the frame stiffener i jacked up the car at the right front (about 5in off the ground) i could not open the doors. lowered the car tighten the frame stiffener bars and raised the right front again, i could open the door. Took the z for a ride Sunday the 22nd, car felt more stable without body flex. I drag race my z and have pulled 60ft times of 1.73 to 1.79 running 11.69 to 11.76 @ 117-119 mph. Next test and tune will be Jan 4, 2014, I'll you know how this works out. Merry Christmas John Becker member #0115 |
