10-24-2014 | #21 |
Re: Z06 rear brake adapters Winter Project
Ok trying to match the front end somebody has to have a solution to retain the parking brake on the standard size rotor I'd imagine. Thanks GC
10-24-2014 | #22 |
Have u checked w =Jeff=? He's using 87 eBrake mechanicals for rear.
10-24-2014 | #23 |
No but I will
10-25-2014 | #24 |
GC stock rear c5 will work with the adapters Dominic has
I just have trouble with the $700 then having to cut and mod things. I am working out a solution to use the 87 adapter then you need the 87 wilwood kit.. I will have more info for my rear set-up in a few weeks.. Using C6 calipers
10-25-2014 | #25 |
GC call me if you want to
10-25-2014 | #26 |
11-10-2016 | #27 | |
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
11-10-2016 | #28 |
It never got installed but here is what I had come up with..
First off the 87 Brake adapter needs to be machined to fit on the 89-later rear knuckle. I have a set that are machined. There is a thin spacer (I forget if it goes against the knuckle or elsewhere in line, I need to look again. The adapter and spacer give you the same depth as the OE Caliper mount on the 89-later Now you have options for the Caliper assemblies:
I actually have a set fo Brembos (big 4 piston calipers) that could be used on the rear, with 2 pc rotors and I have the correct hats with drum in them. I think the Brembo Calipers are a bit too big for me, but if you had a bigger front caliper these would work fine. I even think my 2 pc rotors will work with the Wilwood brackets and Calipers. I never finished mocking it all up, I think it could be done fairly easy, I think WV offered to send me a Knuckle to mock it all up.. I was going to do Brembos front and rear, but swapped for the 6 piston Wilwoods in front and sold the front Brembos.. just never did anything with the rear
