Old 11-25-2013   #21
Z06scentair
Z06scentair's Avatar
Default Re: Developed a miss today.
Just went out and checked the bolt torque and they all seem good an snug!
It efforts to not strip the heads off the bolts I will remove the brake booster for easier access.......ordered the o-rings from jerry today. Anything else I will need or should replace during this venture?
Z06scentair is offline   Reply With Quote
Old 11-25-2013   #22
You'll need the sealer for the cam cover. There is no gasket.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-25-2013   #23
rhipsher
rhipsher's Avatar
Once you get the cam covers off I'd replace that filter material that is stuffed into where the breather tube comes in. You'll find that the 24 year old stuff will crumble like the 10 commandments as soon as you touch it. I just used stainless steel brillo pad and stuffed it in there. But if you want the original stuff Jerry might sell it. The brillo works fine and will last forever.
Old 11-25-2013   #24
rhipsher
rhipsher's Avatar
Loctite 518 anerobic sealer is the stuff you will need.
Old 11-25-2013   #25
Z06scentair
Cool fellows.....as soon as my brother gets caught up at the shop we will tackle this joker!
