#21 |
![]() Join Date: Jun 2013
I like what looks like coil on plug ignition. That would be nice to have on the LT5!
LT5 Red/Red |
#22 |
![]() Join Date: Jul 2005
Love it!
Jerry, what you going to put yours in?? ![]()
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
#23 |
![]() Join Date: Jul 2010
The BBC fits in the C4, remember BigDoggy? This engine is a 552 inch DOHC, TT Mercury produced engine.
Might need a power bulge hood for this engine in a C4. The 1650 requires 110octane race fuel, the 1350 does not. 7.8:1 compression on both. These are Mercury Racing engines, 1 year limited on pleasure application, no warranty at all on the 1650 engine. Length (in/mm)26.69/678 (from back of block) Width (in/mm)34/864 Heiqht (in/mm) 29/737 (from crankshaft centerline) Weight (lbs/kg) 1720/782 Warranty 1-year limited for recreational boating Mercury lists the M8 drive as weighing 280 lbs, so that 9.0L DOHC engine is a heavy beast. 0-150mph in 13 seconds on the water is Miss Geico. |
#24 |
#25 |
![]() Join Date: Dec 2003
In the new Mercury ZR-1 Aerobody.
#26 |
will it fit?
#27 |
doesn't show for sale on their website
#28 |
Wow that's unreal!
Thanks for the update Jerry!! ![]() David |
#29 |
![]() Join Date: Jul 2004
That should be in the next ZR1!
Dave
1991 #1516 Black/Black davidmkelly.com Author of fast-paced, sci-fi thrillers. |
#30 |
Concept Mercury ZR-1350 Aerobody.
