Old 10-13-2013   #21
Default Re: Throttle hesitation diagnostics?
IM is worth it's weight in gold. Think about where it has to survive and what function it performs. Like a number f other systems on the LT-5, the IM is a
Co-processor to the ECM performing functions the base code didn't do.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-13-2013   #22
Franke
I would follow chart A7 in FSM to check fuel system on pages 6e3-A-29 thru 31. Your work looks good so far.
Old 10-15-2013   #23
mike100
Didn't you convert this car to an automatic? It is a good possibility the calibration needs more "accelerator pump shot".
Old 10-15-2013   #24
I worked some silicone / alcohol mix into the IH orifices to loosen the seal, but
# 2 (primary? secondary?) popped off:
Didn't you first pull the clip holding the injector onto the rail?
Old 10-15-2013   #25
mike100
Those seals always come off- forget about it if you can't see it anymore. Just find any Bosch style injector on a junkyard car and pocket a few extras.
Old 10-15-2013   #26
Schrade
I noticed the hesitation when I got it... Wouldn't vac supply to the FPR do that anyway? Or just not enough?
And I've always pulled the injector & rail assembly (and re-installed) as a whole - LT1's anyway. Is it easier to remove the rails withOUT them in place?
Old 10-15-2013   #27
Schrade
Should I pull the IH's next? Or DIS?
Old 10-15-2013   #28
Schrade
Injector looms - will they come up off of the back of the IH's? How?
Or does each wire have to come out of the loom first?
Old 10-15-2013   #29
Do not remove those clips from the injector wire harness (just push on them and they will release)...if you remove them just something more that can fall where you do not want it.
Well, now some trouble.
6 injector connector seals P side fell out. 3 recovered, and 3 MIA. In the lifter valley???
Old 10-15-2013   #30
yes
Does the crossover tube grommet pull straight out of the backside of the IH?
