#21 |
OK - now - FINALLY - got a continuous stream, no interruptions, at 2.5 recordings / second.
How do I upload a stream for everyone to look over here now? |
#22 |
![]() Join Date: May 2013
Big veins = more blood flow = more energy = more fun right.
#23 |
Select post reply - then attach file (paperclip) in menu at top of screen.
#24 | |
I swear musta' been MicroSoft people wrote this program... ![]() So now, I can just upload a .UNI here? Only people with DM can download and play it? Breakin' for a plate of grub and an Ale or 2 right now here... Last edited by Schrade; 10-09-2013 at 05:53 PM. |
#25 |
#26 | |
Also, I think your TPS% is too high for idle. What is the voltage showing as? Should be between .53-.57v. What are IAC counts? DM should have an Export file capability. Just create a .txt file that is comma delimited. Then you can use Excel to open it. |
#27 |
Anyone with datamaster can read your file but Datamaster can export the data to a csv. file which then can be converted with programs such as MS Excel spreadsheet etc. Select file - export engine data -
As xfire says... ![]() |
#28 |
Schrade, my tests show 0% TPS / .57v at idle 700RPM and 0 IAC Position.
#29 |
Those numbers were just ABOVE idle - not idle. THat's where the 'sag' seems to manifest.
Don't know if I got the baud rate setting correct or not. Is that a DM setting? And how do I attach a .UNI file? It's not showing as a valid upload format... - only .zip (compressed format?)... |
#30 | |
Yep. can't up load uni file for sure as its not available. A compressed zip file will work. Baud rate is a laptop thing. |
