Old 10-03-2013   #21
Schrade
Default Re: Interior is almost complete...
first.. some foot bling
Added the 94-95 hush panel in place of the carpet.. the dash there is now split like the 94-95
Defrost vent finally fits correctly:
Black buttons in place of grey
-Figure out how to color the Range and Average buttons so the text is correct vs the 92 ones I have now
-Finish up some lettering on the Seat controls and add it for the power key ( I have a plan just waiting for materials)
- Change the steering wheel.. When I had the DIC out I noticed the 'INFL REST' Bulb is not there so my guess is a ground issue and the PO pulled the bulb. I just would like I Different wheel and eliminate the air bag.
I think that was good work for a Saturday
Looks sharp!
Do you know if this leather hush panel will fit a '90?
Jeff stopped by yesterday since I am starting on conversion of my black interior to saddle/cognac. So I'll have some black interior pieces for sale.
Jeff's interior looks great and he had done the interior lights w white LED and it looked awesome at night w the red interior.
If you have this black leather hush panel, and IF it will fit my '90, PM me here... And I still have my Cognac panels installed here, both sides, after conversion to Black...
Old 10-03-2013   #22
Looks sharp!
it will fit but will require cutting your current dahs pad to make it work.. see my reply to Locobob..
My car is a 90 that I modded for this
-=Jeff=- is online now   Reply With Quote
Old 10-03-2013   #23
Schrade
Robert,
it is not too bad to do honestly.. I had the dash pad out of the car to cut off the carpeted hush area. I cut it right at the indent at the top of the carpet. on my 94+ hush panel the right most tab ( on corner) had broken off and it was actually better that it was gone for fitting it. to hold it up I made 2 short brackets that bolted to the dash structure and I used fender washers with a bolt and nut to clamp down on 2 of the 3 tabs of the hush panel.
It turned out really nice but where the door meets the dash edge the dash is about 1/4 forward of the door which you can see in the picture I had posted.
it does really change the interior.. now to decide if I should go all red with the carpet
Got it there Jeff - my same tab is snapped off too (Dom - forgot that the P-side panel is integrated into the dash; still have the D side, if interested)...
Got snappics of the bracket fabwork there Jeff, for the P side?
Old 10-03-2013   #24
Schrade
Yep - definitely need some shots of the bracket fabwork if you can, even get some blind shots - the flush fit looks very good...
Old 10-03-2013   #25
I will get some, I am just not sure when that will be..
Old 10-13-2013   #26
Fab work, after cutting the dash:
You can see the brackets I added on both sides (with the fender washers)
Old 10-13-2013   #27
I have the Driver's hush panel in a Cognac. It's installed. Do you need black ones because I have both mine.
Old 10-13-2013   #28
Jeff,
After having glued the carpet onto the pass side, the factory should have done it the way you did. Makes it easy to remove and swap.
Old 10-14-2013   #29
Locobob
Thanks for the pics Jeff, so its the tabs on the side by the fuse cover that you don't use/remove, mine are broken off anyhow. I haven't taken the plunge just yet... cutting the dash pad makes me a bit nervous, maybe I need to have a stiff drink before I get started on it haha.
Robert
Old 10-14-2013   #30
The corner most tab under the fuse box cover is gone.. there is another that would be closer to the door jamb/ where the dash meets the jamb that I still am using.. I don't know if it is needed or not but if it is there you are better off
I took those pictures late the other night so I can pull the fuse cover off and snap a picture to help clear the explanation up
