07-18-2013 | #21 |
Re: Finally completed coilover and sway bar install, plus Christmas came early
Looks great! How much time did that work take? Looks like a worth while project!
07-20-2013 | #22 |
It takes 6-8 hours if you have all the parts ready at once. You have to get a grove machined onto each shock. The whole project took me 2+ months but I only worked on it when my friend and I had time. Well worth the time and effort.
CJ Daniel [B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR] [COLOR=red]Frank Approved ZR-1[/COLOR] [SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE] [SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE] [SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE] [SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE] [SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE] [SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE] [SIZE=1]- ASM bolt in 4 point roll bar[/SIZE] [SIZE=1]- 93 ZR-1 Sawblades[/SIZE] |
07-21-2013 | #23 | |
Glad to hear you are enjoying the coilovers and the install went well. Thanks!
07-21-2013 | #24 | |
07-21-2013 | #25 |
Thanks so much and that is awesome. I'll get with Marc and I appreciate the tip.
07-22-2013 | #26 | |
07-23-2013 | #27 | |
What's the width of the groove and the diameter of the shock? Thanks.....
07-23-2013 | #28 | |
I can't thank you enough for taking the time to share detailed photos like this. I really appreciate it and will check with Randy at DRM. Pictures are worth a thousand words as the saying goes and now I understand what is being said about it. Craig
07-24-2013 | #29 |
Shock width is 50.28mm
With snap ring total width increases to 53.28mm The ring is roughly 3mm thick and the grove in the shock body is cut 1.5mm deep. The ring is also roughly 1.46mm thick. Hope this helps
CJ Daniel [B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR] [COLOR=red]Frank Approved ZR-1[/COLOR] [SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE] [SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE] [SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE] [SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE] [SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE] [SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE] [SIZE=1]- ASM bolt in 4 point roll bar[/SIZE] [SIZE=1]- 93 ZR-1 Sawblades[/SIZE] Last edited by CJ_ZR1; 07-24-2013 at 07:36 PM. Reason: numbers |
07-24-2013 | #30 |
Car looks awesome !! I'm curious .. What kind of an airbox is that I see on a few zr1s? Looks aluminum/metal ??
