Old 07-11-2013   #21
LilRedCorvette
LilRedCorvette's Avatar
Thumbs up Re: 402 Build Project Udate
Finally had some time to finnish assembling the 402 motor I've had in the works for awhile. Before buttoning up the cam covers and oil sump wanted to make sure the oil galleries in the block and heads were filled and flowing properly before firing the engine for the first time so I put together this pre-oiler rig. Used the regulator and gauges from my leak-down tester to control the air pressure at 10 psi.
Converted 2 gallon hand sprayer I picked up at Home Depot. Installed a air line quick connect fitting in place of the safty valve.
Engine connection point is the plug fitting located at the top side of the oil filter housing. Made a couple of plugs out of delrin to block off the oil cooler fittings. Inserted a short section of clear hose for a flow visual.
Yep...just threw that together, didya...
The things you make and know just blow my mind.
I cannot wait to see this thing run!
ZR-1/WAZOO 'Wanna-Be'
1994 Red Coupe - DD, Drag, Cruise
1989 Black Coupe - Circuit Track
2020 Black M240i Coupe - AutoX
LilRedCorvette is offline   Reply With Quote
Old 07-12-2013   #22
RHanselman
RHanselman's Avatar
Default Re: 402 Build Project Udate
Phil,
Do you have a target HP/TQ?
Love your work...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 07-14-2013   #23
robrtr
Beautiful job, Phil. Any chance you'll 'close the circle' by doing the swap at a WAZOO WMD?
Ralph
robrtr
'92 #225
Black/Gray
robrtr is offline   Reply With Quote
Old 07-15-2013   #24
Jagdpanzer
Jagdpanzer's Avatar
Originally Posted by RHanselman View Post
Phil,
Love your work...
Ron,
I'd love to see close to 500hp at the wheels and a fat torque curve from 3500 to 6500 rpm.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-15-2013   #25
Jagdpanzer
Jagdpanzer's Avatar
Ralph
Depending on how things go.
For sure at the end stages of the install and the first fire up.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-03-2013   #26
Jagdpanzer
Jagdpanzer's Avatar
After 19 years under the hood the original motor mount heat shield covers were looking pretty shabby.
I've looked around for a while and had no luck finding OEM replacements. I then came across D & H Heat Technology of Mooresville, NC http://www.koolmat.com/index.htm who do a lot of Corvette heat related products. I sent them one of the mounts and heat covers and they came up with a C4 Corvette motor mount cover replacement to their own design using a more modern silicone/fiberglass bonded heat shielding material.
I am very pleased with the way these turned out.
If you are also looking for replacement motor mount heat shield covers I highly recommend this company. They have the paterns now and can fix you right up with a pair.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-03-2013   #27
Jagdpanzer
Jagdpanzer's Avatar
On the the new motor I went with the ATI Super Dampner which has degree markings almost all the way around. The later style LT5s do not come with a pointer like the earlier ones so I made up this one in case I want to do some cam timing later on with the engine in the car.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-03-2013   #28
Vette Guy
Vette Guy's Avatar
Wow! You never fail to continue to impress me!!!
Looking forward to catching up at Carlisle!
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 08-03-2013   #29
Pete
Pete's Avatar
Phil,from what i can see those old covers don't look all that bad,heck mine look worse then those.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-03-2013   #30
HAWAIIZR-1's Avatar
Phil,
Wow, you always take it to the next level. I should have built my motor after you so I could have learned all of this. Awesome! Like Pete said, even your old covers look 10 times better than mine looks when I pulled the motor. Thanks for sharing as always.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
