Old 04-24-2013   #21
WVZR-1
Default Re: Safety Tip!
Originally Posted by scottfab View Post
Im not at all sure that would work. I don't believe there is that much room "length wise) to put that on the polished surface and I know putting anything on it even if it did fit could adversely effect the seal that must slide over the marred and/or contaminated area.
The other alternative is to just rip out the shock/strut and use a branch from a nearby tree each time. It could be a "Green" solution.
I realized as soon as I hit the "submit" that the polished "piston rod" isn't exposed as is most lift support type mechanisms so it's NOT a go thing unless you have the "assist" supports at the hinges and then it could be. I believe the hinge assist cylinders likely have the exposed rod. That might be the better location for the device anyway if you have the assist cylinders. Nothing for the "bystander" to tamper with. Out of reach except to the "knowing"!
I'd likely be the tree branch guy!
Old 05-03-2013   #22
carter200
carter200's Avatar
I have the solution to the hood falling issue. It's visually appealing and can be carried in your pocket when NOT in use. See the Group Buy in the for sale section for details. Thanks........
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
