Old 04-12-2013   #21
Default Re: What say you, Graham?
Here's a thread on the SPLIT BLM issue found in the LT1 if you are interested.
Note this solution works mainly for idle.
http://www.thirdgen.org/techboard/di...ghlight=ULTM8Z
Old 04-15-2013   #22
Well we have determined its NOT a case of leaking injectors. Plenum was off so Pete and I took advantage of that fact to verify injectors are good to go. These are Accels with probably 20k+ on them. Cool. More coming later. We'll be swapping out plugs and O2 sensors as part of the upgrade.
Old 04-18-2013   #23
Hib Halverson
Originally Posted by rkreigh View Post
(snip)
the chevy motors (especially BB chevy) have "good ports and bad ports" that flow pretty differently. (snip)
The Big-Block is the only Chevy engine like that, ie: "good" ports and "bad" ports with a significant difference between the two types.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-18-2013   #24
In the process of doing a bit of upgrading, I think we may have discovered the source of the wide BLM variance. Exhaust leak at the left side collector.
Some times it's a matter of Occam's Razor.
Old 08-31-2020   #25
tpepmeie
Old thread. Dom, was your bank 2 leaner (ie, cyls 2, 4, 6, 8). I've got lab-grade O2s, and a custom fuel rail and regulator. Aftermarket ECU. Have a bank-to-bank lambda offset of .05-.1 Lambda.
Old 08-31-2020   #26
Hi Todd. Good to hear from you. Actually its the left bank(Driver) that is on the lean side. The discrepancy is greater between the two banks at slower engine speeds. At higher rpms, tends to straddle 128 BLM +-2-3 with copious tuning.
Earlier I had a real issue which turned out to be defective secondary injectors.
FIC quickly replaced them gratis. Switched those out along w a new set of coils.
Old 08-31-2020   #27
tpepmeie
Ok. I agree at lower loads and engine speed the variance is greater. I?m running alpha-n right now. There?s something mechanically causing the variation. Have swapped sensors and same phenomenon. I?ve got the iac passage plugged and idling off the primary blade at the moment.
Old 09-01-2020   #28
rkreigh
Hi Todd,
if the injectors are all balanced and ignition / compression good it has to be in the intake not providing good balanced flow. Like you said, something mechanical here. I'd love to tune the car with a haltech or MS pro and see what's going on in each cyl and like Duttweiler says,
"give the engine what it wants and needs"
he does alot of tuning by individual cyl and picks up both efficiency and power
Old 09-01-2020   #29
Hi Todd,
Showing my ignorance here, but I'm intrigued: to tune individual cylinders (I assume) dwell and timing would have to be individually controlled. That would call for some pretty fancy mods to the ECM/DIS, wouldn't it? Please DO TELL. (Always looking for a good article for the HOTB!)
Old 09-01-2020   #30
rkreigh
hi Paul,
Haltech, Motec, Holley and many others can control spark timing and fuel for each cyl
for my haltech I have EGT 8 channel so you can tune trying to get the egts relatively even regardless of AF which does ok.
more advanced systems now have a WB on each cyl to tune AF ratios to target for each
for the LS engines the #7 runs lean so we feed it more fuel
