Old 02-18-2013   #21
LancePearson
LancePearson's Avatar
Default Re: LED Lights for your Clamshell Underhood
Thanks Lance, replaced mine w/ $15 LEDs.Actially mine had the fuse removed by the previous owner and I had been procracinating for the last 13 years.
Even with your heads-up, almost dropped one lense. With out your heads-up I am sure I would be searching for a lense on the Eb*y.
Thank you.
I'm glad someone learned from my clumsy fingers. Scott said another way is to remove the top screw and just loosen the bottom one while holding then slip the lens upward and that works but I still put a soft piece of carpeting over the engine and was double covered.
I'm happy with mine but will still pull the fuse for longer term clamshell hood openings. It's rather easy to do and save the fuse. My new (used but immaculate) lens is in place and all's well. Only replacing a speaker and the radio scratched face plus pull center console trim and check shift boots and put some sound deadening .080 adhesive plus foil faced urethane under the trim pieces to quiet it a bit to go. Parts arrive tomorrow. Getting there!
LancePearson is offline   Reply With Quote
