08-15-2013 | #21 | |
Re: Alternator Problems
http://www.zr1netregistry.com/Inform...r-Rebuild.aspx I am not sure why but this is the second link I've found that is broken this week. I'll investigate..
08-15-2013 | #22 | |
Still no joy. The above link redirects me here: http://www.zr1netregistry.com/Information/TechNet/%5BAllArticles%5D.aspx Ben |
08-15-2013 | #23 | |
Well the Alt rebuild is on that page but..... if you act quickly this one may work for a few hours http://www.zr1netregistry.com/Inform...r-Rebuild.aspx Something is changing and changing a lot. Please stand-by
08-15-2013 | #24 |
There's a quite good 2 part you-tube for the CS144 alternator build:
http://www.youtube.com/watch?v=riYZssdSmXY http://www.youtube.com/watch?v=vKbX7mezuFM I've not watched these in quite some time but I believe it's quite informative. |
08-15-2013 | #25 | |
08-15-2013 | #26 | |
Ben |
08-15-2013 | #27 | |
The part number is right there on one of the pics. Looks like depending on the browser you use the link is different. This works for IE http://www.zr1netregistry.com/Inform...ticles%5D.aspx and this for Firefox http://www.zr1netregistry.com/Inform...r-Rebuild.aspx
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 08-15-2013 at 09:50 PM. |
08-16-2013 | #28 | |
Using that part # and doing some searching I believe if I were doing a rebuild and was interested in a quality build I might source the parts differently. Don't know but the part # or the kit doesn't display a voltage regulator. If there's a reputable automotive alternator/starter shop in the area I'd have a conversation there. Is there someone that does the municipal fleet work, fire ems services An acquaintance was looking for an alternator a couple weeks ago and I suggested that if his were original I'd repair his rather than buy any "off the shelf" reman and he took his to a shop in the area and less than $25 he was out the door with an alternator repair. NOT a "rebuild" but a repair! The bearings are very common and quality bearings can be purchased through most local bearing sources, there's cheap and there's quality. A kit that sells for the Amazon price and is in "multi-lingual" packaging has "other than quality" written all over it. There's quality bridge rectifiers and there are quality regulators also. I'd think I'd certainly shop and have a serious conversation before jumping on a "kit"! Last edited by WVZR-1; 08-16-2013 at 06:24 AM. |
08-16-2013 | #29 | |
Where would you recommend purchasing a kit and what kind? I have a spare kit and like to rebuild it to OEM specs Thanks! David |
08-16-2013 | #30 | |
In your area I'd think there are several. A local audio shop might have a local shop that they recommend for high amperage builds but you're not interested in all of that or "maybe" you are. I'd think you only need parts! Bearings are easy, there's choices in bridge rectifiers and regulators. Which alternator do you have by part number? |
