01-05-2013 | #21 |
Re: Old Borla Exhaust from LPE ... big resonator is rattling, replace with Magnaflow?
That was awesome, thanks for the links.
Haibeck says the Borla regular is 2.5" ... the Challenge system is 3" The guy above says I have the Challenge system ... and claimed it to be 2 3/4". Does anyone know which is correct? How can you spot the differences in the Borla Regular vs the Challenge, just the bigger diameter pipes? Haibeck says the Borla without the resonator is a great setup ... sounds like a plan (easiest , cheapest, with good results ) ... I appreciate the help!!! ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
01-05-2013 | #22 | |
01-05-2013 | #23 |
Its 2.75.....I have it on my car
01-05-2013 | #24 |
Ok ... that's perfect , I was just double checking ... I will have the car in the air Monday anyway ... but thanks again ---
01-05-2013 | #25 |
I note that Haibeck has the Borla system as a 10hp restriction, if you remove the resonator I would have to believe that you get most of the 10hp back, so the mufflers are not a flow issue as some have noted, just the resonator.
01-05-2013 | #26 |
I would have to say I got the same thing out of his studies. I love the sound and the tips ... makes the most sense to just modify this setup since its already installed too ---
01-05-2013 | #27 | ||
CJ Daniel [B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR] [COLOR=red]Frank Approved ZR-1[/COLOR] [SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE] [SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE] [SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE] [SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE] [SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE] [SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE] [SIZE=1]- ASM bolt in 4 point roll bar[/SIZE] [SIZE=1]- 93 ZR-1 Sawblades[/SIZE] |
01-05-2013 | #28 |
Thanks for the heads up about the resonance. Luckily Im not TOO worried about the drone , it actually drones pretty good right now LOL ... compared to the Corsa exhaust on my Viper ---
