Old 12-21-2012   #21
CJ_ZR1
Default Re: Winter Project (Phase 1)
Finally got cam cover emblems and red decals on engine.
Thanks to Daniel M. for the cam cover emblems and Tony D. for the red decals.
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
Old 12-21-2012   #22
Blue Flame Restorations
Beautiful. I really like those plug wires and ground straps. What brand are the wires??? Nology? Where did you get them?
Thanks
Brett
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-21-2012   #23
CJ_ZR1
Thanks Brett
Yes they are Nology and they where put on car by previous owner. I will look through the folder of receipts and see where they were purchased from...
CJ
Old 12-21-2012   #24
Originally Posted by CJ_ZR1 View Post
Thanks Brett
CJ
I just went to their website. They show a cloth braided wire but not solid red like the ones you have. I REALLY like the looks and especially the ground straps. I want some for my 427 stroker project. Very nice, CJ.
Old 12-21-2012   #25
WVZR-1
Hey Brett,
Cloth/CF are "CoolWires" and the wires you want are "HotWires" - in the application chart the only application I see for the LT5 is for the "HotWires" - you get to pick your color!
http://www.nology.com/hot.html
NOLOGY SAYS: "If you're not using HotWires, you're not going as fast as you could be"
Old 12-21-2012   #26
Hey Brett,
Thanks, Dave. I'm going to call them today and see what all they offer.
Old 12-21-2012   #27
Fully Vetted
Fully Vetted's Avatar
Please post with results. I'm curious as well.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-21-2012   #28
2ZR1S
2ZR1S's Avatar
CJ it looks great. The plug wires/screamin deamin coils were bought at one of the gatherings from Nitrous Works. Keep the pictures coming.
Thanks
Jon R. Member #490
1992 ZR-1 Arctic White/Red
2008 Z51 Silver 6 spd (Daily driver)
2ZR1S is offline   Reply With Quote
