Old 11-22-2012   #21
Default Re: What's a "Economical" way to increase our Displacement????
380 bottom end with full top end porting including the heads and Long tube headers and petes cams = the biggest bang for the buck.
Old 11-22-2012   #22
Pete
Pete's Avatar
Have to agree with GC 380ci is the most economical big inch.
Heck i spend almost the same amount and still have stock 350ci
Every Z should have a 380 ci
It would be like LS3 but the LT3
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-22-2012   #23
Pete
I'm so happy my second 380 will be done by march
Old 11-22-2012   #24
alnukem
What is cost difference between 4.00" & 4.125" completed bare block job? I don't know why I'm asking, I am sure I'd have to do the 4.125.
Old 11-22-2012   #25
Polo-1
Pete
I'm thinking more like LT5.3
Old 11-22-2012   #26
Polo-1
$10k
4.00-4.020 $1,000-1,200 drop in LA sleeve. fits factory block. (368-382ci)
4.100-4.165 starts @ $8,500.00 block work (390-450ci)
For Me
If you want big cube go for the 380 then if needed more power hit it with N20
The LT5 really likes the cooling effect of the nitrous. Makes great power with 100-150 shot. RWTQ jumps well over 500 of a 350ci motor.
Old 11-22-2012   #27
RICKYRJ1
RICKYRJ1's Avatar
What kind of hp our we lookin at with a proper 380? Any reliability issues with a offset crank?
Old 11-23-2012   #28
Polo-1
A 380ci should be in the 475rwhp 430rwtq range. Better porting, intake cams...
I would think you could hit 500-515rwhp without too much problems.
Stock cranks have been offset ground forever. Most grinds are .100 as the normal cut. The LT5 offset started with Mike Ebert's 396ci motors, I think. The crank guy I used said it has a ton of meat in it and is a high quality unit. I went with 3.750 (3.66 stock) It looks like it can be pushed out 3.775 without any problems. The SBC small journal bearings come in .001 - .030 under size, so thats not a problem.
Like I have said before, I have done the MEGA $$$ 402ci build. If it were for me or anyone else, go for the 380 it's only a few hundred over the 368 build.
Old 11-23-2012   #29
All very intoxicating, I must say. (Y'all got me starting to drool over a 380 w/ some cams now...)
I ran some numbers based on rwhp/cid for fully ported350s w/intake cams for those of us with "mortal" 350s (est. 450 rwhp) and Pete's insane 474 rwhp 350. For a 380 ci the proportions work out to between 489 rwhp (w/cams) for us "normal" peeps, to 515 rwhp for a setup like Pete's. (He says he keeps the magic formula burried in a Mason jar in his backyard. Maybe that explains why there's so many little pot holes in his back yard...Spoze?)
Anywayz... north of 480 rwhp would make for a lot of low 11-sec LT5s when the team ZR-1 Net Registry makes a run on the club trophy next fall! (But, unless I win the lottery, I'll just have to be happy with my 500+hp, Nikasil 350 (oh, the horror!)
Fun topic!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-23-2012   #30
Polo-1
If you don't need a rebuild and money is tight, tickle that 350 with a nice 100-150 dry shot nitrous. Nothing like 3rd gear and given it a hit and having the 335's let loose on the street.
