10-26-2012 | #21 | |
Re: Oil Level/Comsumption
No they should not be
10-27-2012 | #22 |
.i then just cant figure out what is going on . i havent done anything to either dipstk or tube .
03-29-2013 | #23 | |
Not sure if the exhaust valve stem seal is the cause of the blue smoke or what? What are your thoughts? |
03-29-2013 | #24 | |
03-29-2013 | #25 |
Yep I can relate to that happened. Pre engine exchange that was a daily occurance
03-29-2013 | #26 |
03-29-2013 | #27 |
Sure. You stated you haven't driven much. I am suggesting the blue smoke could be a combination of no valve seals and/or your fuel injectors may have built up deposits that need to burn off with a little spirited driving
03-29-2013 | #28 |
Got it now. Thanks. I'll give it a shot once the rain washes the salt remnants off the road.
03-30-2013 | #29 |
90s don't have valve stem seals on the exhaust, consequently, 90s tend to use oil and start to smoke much sooner in age than do 91-95.
While that blue smoke thing could be injectors–and you can determine if it is by running the fuel pressure tests in the FSM–it's possible that it may be time to pull the heads and have the intake valve seals replaced and have them installed on the exhausts.
