#21 |
![]() Join Date: Jun 2012
#22 |
![]() Join Date: Nov 2011
I'll keep my mouth shut. Well, my fingers off the keyboard.
#23 |
![]() Join Date: Dec 2003
I cannot remember a time when so many political threads were started in such a short period of time on the forum. I suspect it is a case of presidential politics and the election being right around the corner that has spurred the flurry of opposing political threads. That, and how polarized the country is at the moment is also likely reflected in the recent rash of political threads.
Maybe a temporary moratorium on political posts for say the next 60 days until the election cycle ends is in order. After that, I suspect we will return to our primary passion, that being the love of ZR-1's. Any and all thoughts/opinions are encouraged. ![]() |
#24 | |
![]() Join Date: Jan 2009
This is a reasonable proposal but does not address root cause and that is the "New Posts" filter. A separate forum group called "Politics" would if the "New Posts" filter did not report on the "Politics" group.
#25 | |
It would be sad to think we need to permanently restrict ourselves from our own devices. Fortunately, even with the differing political points of view, most have remained respectful and civil, which is what we should expect from mature adults. So to that end, I have no reason to believe that a temporary moratorium of political threads until after the upcoming election will not smooth out this bump in the road. Lets see what others who care to render an opinion think. ![]() |
#26 |
![]() Join Date: Mar 2010
I'd like to see a political free board There are plenty of other boards & sites around the Internet that serve such a purpose.
There are some gray areas, however. For example, what if someone posts a negative story about GM? The problem, sadly and unfortunately, is that government has permeated our society so that everything has a political element, even our cars.
1992 #043, Aqua/Gray 40k miles |
#27 | |
I like it. And just like the 55mph at least when a GM topic comes up we all would know when we're creeping past 65mph. ![]() AND the thread titles that we all have to read from "New Posts" would not get so COMPLETELY political.
#28 | |
I think many things we should do only takes a bad apple to push the cart over. This time the cart was repeatedly being push and I help push because I felt it the right thing to do. I was simply TIRED of seeing the one sided crap every time I logged in. You can call it tit for tat. I call it getting focus on the issue. We have an opportunity to fix this not just shove it under the carpet and say it won't happen again. Because it WILL happen again after the election. How many members would it take saying they don't want Politics on here? Give a number or %. To ignore what people are asking for and do "what's good for them" would be wrong. Either GET RID OF POLITICS or make it so the "New Posts" filter does not show them. Sure even with the "guideline" of no Politics it will creep in sometimes just like a photo may not have the appropriate "G" string coverage based on someone's sensibilities. Be that as it may I submit the G string issue is let objectionable because one can see the title and know what it means without the title being upsetting.
#29 | |
#30 | |
My focus is to try and keep the forum running as smoothly as possible, while still allowing everyone to express their points of view(popular or not). In most instances this has been accomplished with politics being part of the discussion over the last 7 years, since the Off Topic section was created. So while you believe politics will return once my suggestion of a moratorium is over, I suspect things will return to normal as the history of the board has proved. I also would proffer for your consideration the possibility of greater strife saying politics is prohibited. Keep in mind that what is political to one person, might not be to another. Sure the obvious posts of Dem this, or Rep that, are easy enough to spot. However Jcruz gives a perfect example of where criticism of GM can be viewed from a political lens. All it would take is genuine criticism of manufacturing defects that could be blamed on union workers, for some to press the report button as a forum rules violation. Then it winds up being the discretion of the first moderator who sees the report as to whether it is political or not, and what to do about it. Still, with that said, I do not object to the notion of removing political thought from the Off Topic section if that is what the majority of forum goers want. That is why I made a suggestion, and have asked others to give their viewpoints. ![]() Last edited by Z Factor; 09-20-2012 at 11:51 AM. Reason: grammer |
