Old 05-18-2012   #21
carter200
carter200's Avatar
Default Re: Plenum Port + Standard Gaskets = Bad Idea
Originally Posted by rhipsher View Post
No! It's one of my big black butt hairs.
Obama......You are such a kidder
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-18-2012   #22
gbmidyear66
Before I ported the top end, I had a problem with the TB and the secondaries did not seal. I could not get the engine to idle below about 850 RPM (with A/C On).
Now - it idles right down at 650 (so I'm sure vacuum pressure is higher) AND the gaskets were thinned to accommodate the port - so they are definitely dealing with a higher vac pressure and have less meat to them.
Next time its apart (hopefully not soon) I will check the planarity of the IH and Plenum faces and let you know Lee.
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
gbmidyear66 is offline   Reply With Quote
Old 05-18-2012   #23
rhipsher
rhipsher's Avatar
Hey I shed allot. What can I say. Saloma lake loka.
