Old 03-27-2012   #21
tpr60
Default Re: CAN'T PASS CALIF. SMOG, IDEAS/HELP!!!!
YOU GOT THAT RIGHT!!! A real bitch. Found it easier to remove the engine mount nut and remove the mount angle frame brace to give better access. Why couldn't they have extended the harness a couple of inches to make it easy like the left side??? Maybe I should start making a harness extension for the net members???
tpr60 is offline   Reply With Quote
Old 03-27-2012   #22
zr1don
Two options for overcoming the problem with plugging in the O2 sensor on the right side:
1. Make or buy an extension, pull the existing sensor wire out at the rt front side of engine, plug the extension in and thread it down the way it came out. You should fasten the excess wire you now have near the O2 sensor.
2. You can remove the O2 wires from the wire loom up to the rear of the engine (the loom runs under the plenum) and reroute the wires down the rt rear of the engine.
zr1don is offline   Reply With Quote
