Old 02-02-2012   #21
Default Re: Finally Heads are Done
Far as driving in traffic goes, using the Fidanza vs. stock dual mass... I initially noticed just a little (teansy) difference in the necessary throttle and clutch let-out, the first drive or two. Now, it is assimilated, and innocueous.
That said, I do like the snappy accelleration. And, if one is considering a 4.10 gear, the reduced rotating mass would make even more sense, I guess.
I like mine...a lot. No plans to return to stock FW.
YMMV
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-02-2012   #22
Fidanza's Rule -- Just have to get use to the dreaded "gear rattle".
Having a nice ceramic clutch from Carolina Clutch helps a lot as well IMO.
Old 02-02-2012   #23
RICKYRJ1
RICKYRJ1's Avatar
Far as driving in traffic goes, using the Fidanza vs. stock dual mass... I initially noticed just a little (tinsy) difference in the necessary throttle and clutch let-out, the first drive or two. Now, it is assimilated, and innocueous.
YMMV
P.
I feel the same, I enjoy mine and wouldn't go back.
Old 02-02-2012   #24
I hope so the target or my target was NLT than 450 to the rear. Most folks have told me that estimate is way low
Given where stock displacement motors are registering with just porting,
I would agree 450rwhp is probably low when factoring in an additional 30ci. Will you be datalogging and using a WB?
Old 02-02-2012   #25
Blue Flame Restorations
380 bottom end
Full port 36MM top and now heads
Petes intake cams
Jeal long tubes with RT hiflow cats and corsas
ATI Super Balancer
Coplan open air blaster
Was going to install fidanza but David and the ZFDoc said for a daily driver ahhh no
Pretty enviable grocery list.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 02-02-2012   #26
efnfast
Pardon me while I intrude on your post---
How bad is the gear rattle. Will I always think something is about to blow apart?
Old 02-02-2012   #27
I don't notice it, its probably only audible to those sissies that also need 10 layers of quiet mat and exhaust mods to silence "the drone"
Go buy a damn Prius if you want quiet.....
Old 02-02-2012   #28
I get no gear rattle in cruise, and idle can be mitigated with proper tuning.
If it gets louder at idle, its after a long run when trans fluid is hot. Also using the right trans fluid helps.
I use the BMW Castrol 10W-60.
Old 02-02-2012   #29
efnfast
Thanks Guys, nice. It's on the listt for someday.
Old 02-02-2012   #30
Havent decided yet
