Old 01-29-2012   #21
oricale
Default Re: Getting ready to pull the engine!!!!
Hey Jerry,.I did,..VERY minimal damage,..just the plastic pieces for the tensioners,...Yeah I got the harmonic off and will pull the cover off tomarrow and slide the sprockets off to get the chain looses enough to removed the cams ect.
I am also going to remove ALL of the secondary crap!!!!,..
sooo.
heads ported
haibeck chip
secondary system removed
OBX headers
new chains
new tensioners or plastics
pre-oiler
samco rubbers
any other ideas??
oricale is offline   Reply With Quote
Old 01-30-2012   #22
bdw18_123
Originally Posted by oricale View Post
Hey bdw, what parts did you buy to finish the engine?
Did you have your heads redone??...how much??
I didn't have to buy timing chains, sprockets or chain guides because my car came with a second full set of low mile used ones. Another used timing cover in cherry condition was also included.
The main stuff I bought was a full gasket set of course, in my case 6 used valves, one cylinder liner and set of piston rings (used from Jerry) because one liner had some chips in it I think relating to coolant getting in there at some point. Also new rod cap bolts for that same cylinder. I had to buy a power steering reservoir too because mine had one of the mount tabs ripped off and it made a hole.
Yes, I did have my heads redone. My buddy Evan knows a guy local here that is really good with that sort of thing and he had done LT5 heads before, so I got a really good deal for the head work - $400 (he normally charges twice that) for replacing the valves, 5-angle valve job, remachine the head surface, leak test, the whole deal on both heads. I also got new valve seals and had the exhaust valve sleeves machined to accept valve seals (since mine is a '90).
You also need new cam sprocket bolts. I bought mine from Marc, but Jerry has them now too.
And like Jerry said, you will need to remove the timing cover to replace the chains. You'll want to pull the oil pan also, because most likely there will be bits of chain down there (there was in mine).
Old 01-30-2012   #23
Pete
Pete's Avatar
Since he has a chain to replace, the front cover will have to come off. Needs to look around in there and in the pan for any stray pieces & damage.
I did not know there was a broken chain,then yes cover needs to come off.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
