Old 01-24-2012   #21
Default Re: Best Rear Wheel Hub Assembly?
Timken. Make fine other bearings as well.
TIMKEN..the best !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 01-24-2012   #22
batchman
Originally Posted by RHanselman View Post
Any recomondations?
I've come to the conclusion that they are all now made in the same factory in China. Having gone through 1-2 sets of hubs a year for the last few years I have seen random logos mixed up and they all seem to have very similar design. For me they all fail the same way - seal gets overheated, lube leaves, hub becomes junk. Front or rear, and in either front style (we run both ABS styles).
At least I got through a couple sets on Autozone's 1 year guarantee. Now I'm preparing to back date my front hubs so at least I can toss the cheap ones (sensor separate).
If there is play in all directions (ie shake wheel l/r & t/b) it's a hub - if it's tight in any of those directions it's something else.
315 and 335 slicks are addictive, but they extract their price beyond just paying Hoosier... LOL!
Best,
- Jeff
[/I]
Old 01-24-2012   #23
sdycke
The 'one factory in china' analogy isnt too far from the truth in that they do produce different quality parts for differnet customers under the same roof. I know this for a fact. What muddys the waters further is that the SAME bearing can be sold by both a better name brand retailer (eg NAPA) vs a discount retailer with a MUCH lower price (with a MUCH shorter warranty. ie you pay for the warranty). All I can say is from my experience as a journeyman mechanic here, NTN-BOWER seems to work well. Timken is probably the best known and maybe works as well but how many times have i looked at a new Timken bearing and found 'made in Romania' or wherever on it and wondered hmmmmm.....like the set of Dunlops I bought that were made in Poland; with further investigation I found they were made at the Buna rubber plant the Nazis built at Auschwitz/Birkenau. But they ran fine and lasted...I guess thats the price for globalization. Maybe those Romanian Timken bearings were the best out there? Untill I get burned I will continue to use NTN-Bower, because they have held up for me (although I dont race) and definitely have seen many people get burned using white box/private label (autozone, partsource, whathaveyou...) bearings. Thats my experience anyway. PS I'm sure youre aware a bearing that can has no play by feel can definitely growl....buy/borrow an 'electronic ear' set up....its invaluable for times like these (eg customer says LF is noisy but you can tell him, sorry sir BOTH front bearings are noisy, LF more so....or no its just your tires or torqrue converter etc) cheers! Uh oh. last call.....In short, go with what you know or trusted people advise but know that globalization can change it all in a heartbeat, as when my beloved NTN bearings are sourced from North Korea or Cuba when the opportunity presents....
sdycke is offline   Reply With Quote
Old 02-04-2012   #24
RHanselman
RHanselman's Avatar
Put the Timken’s on and no real change so tonight I swapped the tires around between the turbo car and #140. Yep it worked, no more noise...
I guess I have two good use bearings in storage now...
Cheers,
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 02-18-2012   #25
4DSZR1
4DSZR1's Avatar
Put the Timkenā€™s on and no real change so tonight I swapped the tires around between the turbo car and #140. Yep it worked, no more noise...
Cheers,
Hi Ron, Where did you buy your Timkens?
Thanks
Rick
4DSZR1 is offline   Reply With Quote
Old 02-22-2012   #26
RHanselman
RHanselman's Avatar
Thanks
Rick
Rick,
Got them via the AutoZone website. They offered a $20 gift card for every $100 so I got two for the purchase...
Cheers,
Ron
Old 02-22-2012   #27
4DSZR1
4DSZR1's Avatar
Rick,
Cheers,
Ron
Cool :-)
Thanks
Rick
Old 02-25-2012   #28
phrogs
phrogs's Avatar
I have two complete sets of rear end parts if anyone is interested.
JOHNNY P
Currently own
