Old 01-11-2012   #21
Corbusa
Default Re: Ok got a Real good Electrical problem come on in
For the 1990z are there aftermarket ECM's ? or where would a person get one to keep on the shelf? Expensive.? The reason for my questions are I hope to keep my ZR for a very very long time and I need all the education I can get and slowly get parts I can afford.
At BG this year is there anyone that brings parts etc for educational purposes? Thanks Sorry I didnt mean to Hi-jack the thread..
Old 01-11-2012   #22
My money is on the quad drivers which control the injectors. In MY92 these became part of the ECM and chip circuity. We are however talking about Johnny's MY 90. Johnny swap your drivers (They are identical) then tell us which side is firing incorrectly after the swap
I sent you a PM as well. GC
Old 01-12-2012   #23
Mine is a '90, and I wuz thinking about them too (I assume we're both talking about the two quad relay modules?). But, looking at the schematic in the FSM, the primary injector current does not pass through them; only the secondaries (two quads = 8). Based on what I've read has been done - not actually being there - the ECM is floating to the top of the suspect list for me too. (Note the cautious tenor, as I (we all) have been wrong once or twice when it comes to 'lectrik chit!)
I seem to recall there are at least two schematics in the FSM touching on the ECM, DIS, and injectors... I'll keep looking, but my money is on the ECM (at the moment).
Thinking out loud, I know Marc Haibeck provides ECM service (sends them out, if I recall), so if it is the ECM, then there is a solution to that problem.
I tell ya...dealing with GM to get information on repair parts - or even just spec sheets - is a real PIA. I'm just sayin...
P.
Old 01-12-2012   #24
P.
Yeah Paul, Johnny said he has already tried (swaping the drivers) so its on to the ECM I guess. Also the QUAD drivers only affect the secondaries and not the primary injectors. Its hard to believe only one injector out of one bank is effected by the ECM although. I know he said the harness was good but maybe there is a micro break somewhere in the harness. Anybody have an ECM to loan him. I dont? GC
I really hate electricial problems
Old 01-12-2012   #25
ittlfly
Originally Posted by phrogs View Post
so what signals the ECM to fire the injectors?
something must tell it that it is time to fire. Is it the Camshaft sensor?
I am trying to reduce the possibilities of other things being broken other than the ECM but it looks like it is the ECM all day long..
FWIW... even with a bad cam shaft positioning sensor the engine will run and fire all 8 injectors. If it was a bad sensor it would be coding out #31. I have a new GM OEM cam positioning sensor if you are interested. A new Gm one can be hard to find. I scored a new one fron Chris over at Superior Chevy in St Louis awhile back. Cheapos are a dime a dozen....
ittlfly is offline   Reply With Quote
Old 01-12-2012   #26
ScottZ95ZR1
ScottZ95ZR1's Avatar
I think I'd like to buy the sensor if Johnny doesn't need it, Steve.
ScottZ95ZR1 is offline   Reply With Quote
Old 01-12-2012   #27
ittlfly
PM sent..
Old 01-12-2012   #28
Pete
Pete's Avatar
Yeap,what he said.
Try it yourself unplug the cam sensor she will start and run but will get SES light.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-12-2012   #29
Originally Posted by Pete View Post
Yeap,what he said.
Pete
The cam sensor is used by the ECM for sequencing the injectors. Basically it tells the ECM where #1 cylinder is. After that the ECM "knows" what the firing sequence is. I like the idea of swapping harness connectors and seeing if the "new" #6 now fires.
As for the primary/secondary operation, recall that the LT-5 ECM is essentially an L-98 ECM since it was too costly to develop and certify a purpose built engine control system. The L-98 has 8 injectors. To drive the additional 8 injectors the LT-5 uses the primaries to provide the firing signal to the secondaries. The secondary relays are used to provide the power. In a way, its a bit like the operation of the LSx coils. The ECM only provides the firing signal, the power comes from the BATT.
Old 01-13-2012   #30
phrogs
phrogs's Avatar
Yeah the Secondary Modules have been swaped sometime ago just for giggles and it didn't change anything but again they are for the secondaries. The ECM controls the Primarys.
It might be a problem finding a replacment ECM. Plus Im about to be moving again since I got my Job offer out in New Mexico. Working on CV-22s for the Air Force. Never thought I would be a Military Contractor LOL
JOHNNY P
Currently own
