Old 05-24-2005   #21
supercowboy
Default
Originally Posted by Z Factor
Originally Posted by supercowboy
Is this done with the stock compression? Was The head gasket replaced with a thicker one?
I don't know the answer to your question, but wanted to welcome you to the forum.
Hopefully 240ZTT will be back to let you know.
Thank you for your hospitaliy
supercowboy is offline   Reply With Quote
Old 05-24-2005   #22
bigd
bigd's Avatar
Default
Cowboy, To answer a couple of your questions, here is some information I got from reading some other posts. 7.5psi with two Garrett GT30R turbochargers. 565rwh/532rwt- before the Xpipe.
Don
bigd is offline   Reply With Quote
Old 05-24-2005   #23
supercowboy
Default
Don
I just realized that after my post. Thanks for pointing that out. I feel like a blonde
Old 05-26-2005   #24
rkreigh
Default
the stage I is now going back to be converted to a stage II with lower compression and high boost. same basic setup for the manifolds, turbos, plumbing, and intercooler.
the stage II is the one to really watch. with high compression, only low boost is really possible, but it allowed to sort out the configuration and get an idea of how well things will work. the stage II will really run some big numbers but obviously will cost more since you need to do the 368 conversion too.
only way to fly IMHO. turbos and high compression only work really well with race gas or alchy if you are running enough boost to make it worthwhile.
SGC definitely got some impressive numbers out of the stage I, but the stage II will be the monster.
stage I is a great alternative to a full boogie 415 as it produces very similar power numbers and a stock idle.
the stage II will rotate the earth, with those same great street manners!!
my daily driver is a buick turbo, and it does really well for a bent 6 buford.
the turbo tech is where it's at!!!
Old 07-28-2005   #25
RiceEatingZR1
RiceEatingZR1's Avatar
Default
Holy Cow! so those numbers were from a Stage I with stock Compression. any update on the Stage II?
RiceEatingZR1 is offline   Reply With Quote
Old 08-03-2005   #26
ZROne
Default
Ron, do you know if they are going to integrate with existing 368's or will SGC be doing these only on their own builds?
Chris
1994 ZR1 (Yellow)
ZROne is offline   Reply With Quote
Old 08-03-2005   #27
rkreigh
Talking
engine will be redone with low compression pistons but a 368 would save the bucks on liners/rods, ect..
I have a pristine rotating assembly from my stock 95 lt5 *lpe take out parts from my original car* cool stuff
I believe it will take some time to sort all this out as these projects take alot of r&d
great to see SGC doing this stuff. I think a 390 TT should be in my future but it's a way out. gotta wear out this stroker first.
Old 08-03-2005   #28
Kevin
Kevin's Avatar
Default
Give it to me Ron.....I'll ware it out during my 45 mile round trip commute.
Old 08-17-2005   #29
zr11990broken
zr11990broken's Avatar
Default
Hy guys I decided to see what you are talking about over here. I like the babes section. I wish my wife looked like that but I bet shed be a real pain in the butt if she did and I couldnt afford her anyway. Back to the subject, Bill Kirchhoffer told me he built a S/C lt5 talk to him about it.
zr11990broken is offline   Reply With Quote
Old 08-17-2005   #30
cuisinartvette
Default
That's a real healthy torque curve! I can only imagine how it must feel to be sucked through the back of the seat! Who's going to be first?
