Old 10-11-2011   #21
Pete
Pete's Avatar
Default Re: 1990 LT5 368 with stage 1 cams performance issues
And more will follow suit.. the 90 injectors don't like ethanol. if you want to save some $$ you can buy FIC rebuilts, they have a 3 year warranty..
I have these on my 90
http://fuelinjectorconnection.com/sh...&productId=165
Wow nice price.
I agree with Jeff change them all,and do the job once they will start to go out one at a time.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-11-2011   #22
blr33439
I spoke with John at corvetteinjectors.com today and he was very helpful. I ordered the New Lucas injectors and should have them in a few days. I will post an update once the install is complete. Any other recommended maintenance or inspections while I have the plenum off.
blr33439 is offline   Reply With Quote
Old 10-11-2011   #23
Kevin
Kevin's Avatar
if the wires need changed do that, check the drain hole in the V, it gets junked up. And whats the deal with your av...it looks like a c4 headlight but not
Old 10-11-2011   #24
it is his new headlight big thread at CF about it
Old 10-11-2011   #25
blr33439
Good idea. I think the plug wires are fairly new so I will check them with the multimeter(what specs should I expect for good condition). Also, what is the best way to check the coils? I already pulled a couple plugs to check the condition and they looked ok. The previous owner said the engine has eaten a few plugs in the past(don't know if this is normal or caused by other factors). Recommendations on plugs?
Old 10-19-2011   #26
blr33439
I reinstalled the new fuel injectors and the fuel rails yesterday before the sun went down. I have a question on the three electrical connectors that attach under the intake plenum. The only part designation I could find was 6ped and 7ped. Am I looking in the wrong place for part numbers or is there a corresponding number. I want to replace the connectors since they are brittle and one clip broke upon removal. I have looked at several online connector websites, but I don't think I have the right part number.
Old 10-19-2011   #27
QB93Z
QB93Z's Avatar
I have also been trying to find the correct replacement for the Ignition Module connectors, but I haven't had any luck so far.
Here are the connectors for a 1990:
The later model LT5's also have a connector for the Secondary Vacuum Pressure Sensor.
Please let us know if you find anything.
Old 10-19-2011   #28
Google search is your buddy.
http://www.repairconnector.com/categ...IL-CONNECTORS/
Providing the connectors are not in real bad shape. Sometimes they can be held together with a tie strap or two.
Old 11-03-2011   #29
blr33439
Starter went. Hear a high pitch spinning but it is not engaging the motor. Anyone know where to get a rebuild kit?
Old 11-03-2011   #30
sammy
have used the napa rebuilt starters in both my cars with great success . price is reasonable too
