Old 08-19-2011   #21
cvette98pacecar
Default Re: New Shots of the Beast
Very Nice. What do you have for rims?
Old 08-19-2011   #22
USAFPILOT
USAFPILOT's Avatar
Those area 3 piece wheel manufactured by Speed Line for the Shelby Series One.
Old 08-19-2011   #23
gtabert
gtabert's Avatar
I like the wheels as well, are they hub centric? What size are they? Do you use spacers, if so what size? I'd be a bit worried about undo stress on the bearings if spacers are used. Last question, what size and brand are the tires?
[FONT=Arial]'95 ZR-1 #143[/FONT]
[FONT=Arial]Comp. Yellow / Black[/FONT]
gtabert is offline   Reply With Quote
Old 08-19-2011   #24
USAFPILOT
USAFPILOT's Avatar
18x12 and 18x10 I think. The rears are using 335/3 Michelin PS2's and the fronts 275/40. The don't need spacers since the Shelby series one was apparently designed using C4 suspension and brakes. They bolt right up but only on a ZR-1 due to the extra space under the fender. The will not clear big brake kits on the front unless you swap the center to the outside of the wheel and get a spacer. I am using stock brakes so there is no problem.
Old 08-21-2011   #25
93RubyZ
93RubyZ's Avatar
Very nice!!
93RubyZ is offline   Reply With Quote
