Old 08-06-2011   #21
Default Re: Help!
Originally Posted by mgbrv8 View Post
Okay I set my VOM to read DCA and connected the red lead on the pos side of the battery and the black lead to the pump test lead and I got zero. could I have a faulty fuel pump relay? Okay my local guys dont have bosch pumps available but the to have the equivalent in Airtex E3270 will these be okay??
I replaced both of mine with the Airtex pumps & Marc Haibeck says he's used them successfully. They seem to work just fine in my car.
Note: I did have a check valve problem with one new Airtex, but was able to exchange it for one that was good (at AutoZone). I don't mean to cast dispersions on Airtex, but rather to suggest blowing air (used my mouth) on the outlet tube to see if check valve was operating before installing the pumps. Just a thought.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-06-2011   #22
lbszr
lbszr's Avatar
Default Re: Help!
Is there 0 resistance from the plugs ground to the sender unit base. Could of lost ground which would make both not work, I agree seems odd both pumps would fail.
If there's good ground connection can you connect you VOM red lead to the grey or grn/wht and ground the other lead to the pin in the plug at the same time your applying power from the alternate power source to verify power is getting there.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 08-06-2011   #23
mgbrv8
Default Re: Help!
Are these the right strainers for the pumps??
Old 08-06-2011   #24
lbszr
lbszr's Avatar
Default Re: Help!
It looks the same as the one I put on my primary, the area of it was close to the original. The secondary original strainer on mine is twice as big though and wraps upward. But I don't know what other choice you would have, unless the dealer still has them. But I don't think I would worry about it.
If your want to do some R@D.....install them on both and check that fuel pressure at WOT doesn't fall off.
Old 08-06-2011   #25
lbszr
lbszr's Avatar
Default Re: Help!
Does yours have the flat gasket at the sender unit, or big O'rings? Mine has the flat rectangle gasket and had to get it at the dealer, $22.
Old 08-06-2011   #26
mgbrv8
Default Re: Help!
How would I check the ground at the pumps without having to pull the pumps. Either way it looks like I need to pull the pumps. I ran a direct ground from the battery to the black wire going into the tank I then ran a jumper to the green and then the grey. still nothing. I am going to buy the pumps and strainers right now before the parts houses close for the day. Any input would be greatly appreciated.
Dave
Old 08-06-2011   #27
Default Re: Help!
You're way ahead of this posted question now, but for the record, the test lead is between the pump relays and the pumps; they are out of the test circuit, and it matters not if they are working or not, far as testing the pumps goes.
As for both pumps going out at the same time, that would be unusual, at the least. More likely the secondary pump failed sometime before and was never detected until the primary pump failed...would be my guess.
P.
90 #1202
Sans secondaries
Old 08-06-2011   #28
lbszr
lbszr's Avatar
Default Re: Help!
Dave
Yea.....looks like your up to pulling the pumps, wiring will be obvious then.
This could help verify a bad pump, my pumps had 5 or 6 ohms of resistance when removed, and the bad pump was "open".
Do you see any sparks when you connect the jumper wire to run the pumps, should be a visible one....and be careful for GS
Old 08-06-2011   #29
mgbrv8
Default Re: Help!
Nope I didnt see any sparks
Dave
Old 08-06-2011   #30
lbszr
lbszr's Avatar
Default Re: Help!
Dave
Good luck, sounds close to a fix, could only be the short runs of wire in the sender, or pumps.
You might be able to reuse the sender gasket if the pump kit doesn't have one. Mine was too old though.
