Old 07-21-2011   #21
Default Re: What is the expceted Fuel Rail Pressure when driving
Originally Posted by QB93Z View Post
My problem turned out to be injector related, not the fuel system. One problem that complicated the trouble shooting was that the fuel pressure tester I was using has a problem with the fitted that attaches to the schrader valve on the fuel rail. When the fitting was screwed on tight, the pressure gauge would not display fuel pressure. Very annoying.
I have one of those models also....very annoying!
Old 07-21-2011   #22
scottfab
scottfab's Avatar
Wow, makes sense for the code 55 with an injector problem. I suppose my attaching a fuel pump to this thread is dubious. Oh well, someone searching for "fuel pump" will hit on it.
Scott
Old 07-21-2011   #23
QB93Z
QB93Z's Avatar
The tech manual trouble shooting chart for a lean condition starts out with fuel system diagnosis, so I eliminated that first before I pulled the plenum to look at the injectors and wiring.
Old 09-11-2013   #24
Dream car 90
Dream car 90's Avatar
I'm also showing the infamous code 55 , I replaced the fuel filter and checked fuel pressure for primary and secondary fuel pumps both read @ 50 psi , so next step is to remove plenum and tackle the injectors .
Dream car 90 is offline   Reply With Quote
