Old 05-21-2011   #21
VetteMed
Default Re: Beware charcoal canister breakdown!
My Standard Part Number PF 1031 canister came in from Rock Auto today it is also stamped Rochester on the top. Just FYI. Thanks for the tip again Andrew.
Glad to help, Daryll!
Old 05-24-2011   #22
HAWAIIZR-1's Avatar
Okay, guys. Here we go again with the unique 90 MY stuff. I see that there is a different part number for the cannister (almost double the price), but the valve is the same as other years:
1990 CHEVROLET CORVETTE ZR-1 5.7L 350cid V8 MFI (J) DOHC : Emission : Vapor Canister WikiPriceSTANDARD MOTOR PRODUCTS Part # CP1032 {#17113150, 215155}
$94.79Add to Cart ACDELCO Part # 215155 {#17113150}
CANISTER,EVAP EMIS
* Non-stock item--shipping delayed up to 5 business days$81.99
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 05-24-2011   #23
VetteMed
Looks like it has the purge valve built into the top of the canister, unlike the 91 which has the purge valve in the tank, and the canister has no moving parts. Bummer.
Old 05-24-2011   #24
VetteMed
Also, note there's a solenoid and a valve - solenoid under the plenum sometimes incorrectly gets called a valve.
Old 05-24-2011   #25
HAWAIIZR-1's Avatar
Okay, thanks. I'll try to take a look at it first and confirm the part number on the original before ordering anything. It seems we have a few unique items on the 90 MY...........what a pain in the arse.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-24-2011   #26
yes 90 is different, those pictures you posted are correct.
1990 Canister is up front under the left headlight
Old 05-24-2011   #27
xlr8nflorida
xlr8nflorida's Avatar
How much is it for 90?
Old 05-24-2011   #28
HAWAIIZR-1's Avatar
Thanks Jeff, I was wondering about that and a lot easier to get to so that is a plus.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 05-24-2011   #29
Yep the 91 Replacement I received over the weekend looks nothing like that. Great catch Craig and yet another in the only My 90 club. Just like the Air pump etc.
Old 05-24-2011   #30
ZRapid-1
VetteMed,
Thanks for this post. Your timing is remarkable.
I have a 90 which has just started exhibiting similar symptoms.
When I used to turn the key, the engine would crank for a few seconds and then start running.
Now when I turn the key, the engine starts running instantly. There is no delay in firing up.
I noticed the difference but did not know why.
In reading some of the replys, you did not explicitly state that the replacement of the canister and purge valve cured the problem. Did it? Is your car back to cranking for a few seconds before starting?
I also see that the 91 MY charcoal canisters are mounted upside down. This leads to broken down charcoal in the lines and then subsequent disruption of purge valve operation.
Has anyone else seen this as a problem in the 90 MY?
Does anyone else have a 90 which fires as soon as the key is turned and what have they done to troubleshoot and remedy the problem.
Thanks in advance,
ZeeAreOne
ZRapid-1 is offline   Reply With Quote
