Old 05-20-2011   #21
Default Re: Thermostat Housing "REPRO"
Yep. Thats what I was thinking the original thermostat looks like a jarvic heart for just that reason.
And pretty much thats where the price came from.
Old 05-21-2011   #22
Originally Posted by tpr60 View Post
Local rod builder has a mid year with a LT5 he is building. No thermostat housing. Made a plate to hold a small thermostat for each water neck, looks like it should work.
I'm not trying to be a wise guy so don't take this the wrong way. When i first read this I thought "now that's slick!"
However upon further reflection some things stumbled into my thoughts.
What happens if one fails and one doesn't? My correction would be to use the AutoZone "fail safe" stats, they fail 1/2 open.
What happens if both do not open & close at a rate say within 10% of each other? On an open deck motor I don't know if that's a good thing. I'm thinking flow restriction out of each side of the block and the resultant PSI build up under each head. I'm thinking steam pockets & turbulence?
Not trying to be a wise a$$.
Brett, sorry for the Hi-jack.
Old 05-21-2011   #23
Tom your not a wise ***. Your one of the most "thoughtful" for the benefit of others meember on here. The solution presented may work well for that rod solution but I really dont think so. However I remember reading in the HOTB about the specific issues and totally different circulation issues that were used by the GM engineers specifically for the LT5. Steam Pockets, turbelence and cavitation could be real key problems.
Old 05-24-2011   #24
tpr60
Thanks guys for your thoughts, I passed them on down the line. Two or more heads are always better then one.
Found a Jag separate thermostat housing similar to the zr1, will let everyone know if it works out.
tpr60 is offline   Reply With Quote
Old 06-15-2011   #25
Blue Flame Restorations
Default Update
Just an update to the project. I am having the housings cast and machined. The units will look very close to original, afterall. Machining will be performed on the Bridgeport. Once machined, the rest will be pretty straight forward.
More to follow as I progress.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-16-2011   #26
Way to be Brett!
Old 06-16-2011   #27
=D>
Way to be Brett!
Tom, your extra unit is in the pipeline, for all the help and parts you have given me with the 88.
Old 06-16-2011   #28
Brett, I'm trying to think of how I say "Thank You" after reading your post. Some how just saying "Thank You Brett" just don't seem to cover this.
You Sir are a gentlemen and a scholar, and a great judge of fine whiskey and motor cars! Thank You!
Hey, do you need ignition coils for Elvis? I found my OEM/BG coils that I swapped out from my car? Oh, they work too even at 15 yrs old & about 14k miles. I swapped them when my OE injectors went out to lunch.
Old 06-16-2011   #29
VetteMed
Brett, that's great to hear! it's nice not to have to be in the crosshairs of parts hoarders :-)
Old 06-16-2011   #30
No need to thank me, Tom. Gald to do it. The 88 has new injectors but I appreciate the thought, as always.
