05-20-2011 | #21 |
Re: F!!!! Oil Leak...
Paul,
That makes me feel a little better (I guess LOL). I lost about a quart and a half of oil when the sensor went. I have some of the ?freckles? under the passenger side floor board and rear wheel well. Daniel |
05-20-2011 | #22 |
I had a problem with a leak and it was caused by one of the bolts (there are only 3) holding the oil filter housing losening up causing a leak.
It might make some sense as Jerry mentioned to remove the oil filter adapter if you have clearance problems. I'd use a new gasket (from Jerry) and torque the three bolts as shown in the FSM. I think you are supposed to use threadlock on them, check the FSM. Good Luck
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
05-24-2011 | #23 |
jrd1990zr1,
I did just that. I was worried that I might have to remove the filter adapter so I went ahead and got the gasket. Do you happen to know the torque #'s? I need to get a FSM! Daniel |
05-24-2011 | #24 |
I think this is the source of my persistent oil leak as well. I was pretty stupid for not replacing it when I last had the filter housing off.
05-26-2011 | #25 | |
Thanks Andrew
05-26-2011 | #26 | |
Daniel, I'll look it up and post later tonight. Sorry for the delay in responding. John
05-26-2011 | #27 |
John,
Thanks! I honestly haven't had a chance to do anything with the car the past 2 days. Hopefully tonight I will have a couple of hours. Daniel |
05-26-2011 | #28 |
7mm or 8mm and yes oil can leak from there. if you can get to it.. let me know how, I want to check mine as well
05-26-2011 | #29 |
I've got my oil filter housing removed right now, and am thinking that while my AC system is apart, I may have some extra clearance to reach down in there with a box-end wrench. I will let you know what I am able to come up with.
05-26-2011 | #30 |
Daniel,
19 ft-lbs Good luck, John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 05-26-2011 at 08:16 PM. |
