04-24-2011 | #21 | |
Re: car pulsates under load when in power mode
Also, in my travels i noted a Corvette specialty garage on the 401 somewhere between Oakville and cambridge...not sure where exactly but it was called Grand Sport Corvettes. Might be worth giving them a call and asking if they do service on lt5's. |
04-25-2011 | #22 |
Just to chime in and suggest starting with something easy. I didn't believe it could be this simple, but someone here insisted and they were absolutely right.
Tighten the battery connections. Worth a shot. You will need the other stuff anyway, but it seems the 2ndary fuel pump and injectors are a significant electrical hit and these side terminal batteries are marginal at best. Best of luck, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
05-03-2011 | #23 | |
Sorry guys, im not a handy tech guy like you all seem, and doing this job myself is out of my league by a long stretch. The references to Ohm's do confuse me. I have a good rapport with my garage in town but they have not worked on an LT5 before. I'm really not sure where to turn next as I brought the car to the garage and had the fuel filter replaced, the throttle body cleaned, and some injector cleaner placed in the tank. They thought if I drove it for a bit it would correct the problem. I took it out for a drive but as the weather has been crap have not had an opportunity to really drive it. I can hear the vaccuum pump running for several seconds when I turn the key to the accessory position, so that would not appear to be the problem. Not sure if I want to invest $1400 for a set of 8 secondaries plus however long it takes the garage to install it without knowing for sure thats my problem with the car. With everything I read on this board I am confident the secondaries are my problem, but just not 100% sure. Thanks for any input you guys have. |
05-03-2011 | #24 | |
FWIW, I bought a set of 16 injectors from Jon Banner (Fuel Injector Connection) for under $400. http://fuelinjectorconnection.com/shop/ http://www.corvetteinjectors.com/sho....php?groupid=3 Replaced them myself. I am definately not a tech guy. This was the first time I ever tried to do a repair such as this. If you use the instructions here on the registry and have a new set of primary o-rings and a spare set of plenum gaskets from Jerry's gaskets the job isn't that difficult. http://jerrysgaskets.com/store2/root/ Just make sure to drain the coolant down enough and use the procedure to refill coolant. This is probabily the most difficult part.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
05-03-2011 | #25 |
Awhile back, I started making up gasket & seal kits for the most commonly done procedures, in response to many emails asking "What all do I need?". Here's a link for the Fuel Injector Maintenance Kits, 90~92. The only choice you need to make, pertains to which type of seals you want.
Basically, Buna-N is best for 100% gasoline and also happens to be the least expensive. Viton is the best for Ethanol/Gasoline blends, but is more expensive. 90~92 Buna-N kit http://jerrysgaskets.com/store2/root...roducts_id=458 90~92 Viton kit http://jerrysgaskets.com/store2/root...roducts_id=459 Please note that virtually all new injectors come with o-rings installed already. That particular o-ring seal is PN1712222. If you are using new injectors, save some $'s, refer to the kit contents list on the website & get everything separately, except the 17112222 o-ring seals.
05-03-2011 | #26 | |
now you have me wondering if i bought the right injectors from summit racing? i got the part number from this reference by a zr1 specialist. http://www.zr1specialist.com/HAT%20W...eplacement.pdf he states that accel 150821 is a dirrect fit for the 91 zr1 and he uses this brand often on customers vehicles. Can anybody confirm if purchased the right injectors for my secondary injectors? acc-150821 8-pack 21 lb/hr $300 from summit. |
05-03-2011 | #27 | |
I would have to look, but I thought mine were yellow though.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
05-03-2011 | #28 | |
05-03-2011 | #29 |
Well, just ordered a set of 16 from Corvetteinjectors and the gasket set from jerry'sgaskets..
Anything else I need that anyone can think of? Spoke to my shop and they quoted about 3.5 hours to do the job. Thanks. |
05-16-2011 | #30 |
just installed the parts i had mentioned before...secondary injectors and coil packs and it fixed the car! thanks guys for all the help and now i can enjoy the extra 200hp
