Old 04-01-2011   #21
Locobob
Default Re: Ride and suspension questions
Guys,
Thanks for all the thoughts and ideas that I will address when I meet up with it next month. I did try to bounce the rear and there is no give (not an inch anyway) so I'll do some checking and as mentioned if I can get it on a lift it would be good too. I will also try to meet up with one of the Z brothers there and do some comparisons. Everything was very tight with the polys for sure and I should have done more checking for binding upon assembly.
Hmmm, did you put the rear sway bar on backwards? I did that once and had similar symptoms.
Robert
Old 04-01-2011   #22
HAWAIIZR-1's Avatar
Thanks, I will check that out and did not even think or know that it was possible. Once I get the car in the next two weeks I'll check this out.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-01-2011   #23
Locobob
Yep it's quite easy to do if you're not paying attention. The car will feel like it's all bound up and ride like crap with the bar upside-down.
Robert
Old 04-02-2011   #24
HAWAIIZR-1's Avatar
Okay, that will make me feel like a putz alright. If anyone has a photo of a correctly installed rear sway bar that will be good?
Thanks for sharing Robert!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
