#21 | |
![]() Join Date: Dec 2004
The trick of Hib's with the EGR is a sweet one! I have a 90 so I would have never thought of that trick! Kudos Hib!! ![]() Tom
#22 |
In response to the inquiry about NOX and temperature, its true higher "combustion" temps will increase NOX, but thermowrapping promotes higher exhaust system temps, including raising the temp in the cat. The increased cat temps increases the efficiency of the cat reducing NOX.
#23 |
![]() Join Date: Nov 2007
Don n Mike...
All very interesting stuff. Copied and pasted, against the odd chance I end up in Colorado, or some such other. Thanks for the detailed post! ![]() P. |
#24 | |
![]() Join Date: Jun 2005
Over the years, I've gotten the story confused. CAGS does, in fact, exist for CAFE and avoiding guzzler but it also enabled the ZR-1 to get though the pass-by noise these, which back then, was only in the State of California. Fuel economy was the main reason. California Highway Patrol's Pass-by noise was a second benefit. Sorry for the confusion. I rely on what I remember happening too much sometimes.
#25 | |
Cats can get so hot the substrate fails and then you're in worse shape that before. What I do before testing is take a 5 mile run on the freeway in 4th or 5th gear then pull into the test station. If the test station is not near the freeway, I'll drive around the block a couple of times in first gear. Either way gets the cats hot. |
#26 |
Well,just got back from my friendly neighborhood smog nazi and my Haibeck chipded,other wise 100% stock 18,000 mile 1991 ZR-1 FAILED!On NOX I think its 702 with a 502 max.So whats my solution here guys?Drove the car for 20 miles right to the smog station.Stock chip,octane booster and what brand of gas Im not sure.How do I get this this thing to pass?
#27 |
![]() Join Date: Feb 2011
You need to post the entire test result, but my NOx was 700 when it had a gaping vacuum leak under the plenum.
went to 390-400 when it was fixed. |
#28 |
![]() Join Date: Mar 2004
I have read that thermo wrap on the headers would cause the metal to become brittle over time. Is there any truth to this? I thought about wrapping mine for several reasons.
#29 | |
Unfortunately, if the engine is running right, 90-92 owners have few options as far as EGR because they don't have an EGR valve. Plus the State of California wants to force old cars off the roads and one way it does that is by lowering the emissions limits which has been done at least twice since 1995. First, stop using octane booster. Few of them are effective and the ones that are (which use MMT as the active ingredient) can damage your cat converters. Specifically, what brand of octane booster have you been using? Secondly, I'd inspect the engine looking for anything that will increase combustion temperature which raises NOx emissions. Check the engine over and report back to the forum on your findings? Lastly, can you post the full results of your test?
#30 |
I think on the other forum you clarified that you were not running the stock chip and plan to revert before re-testing? that would be a biggie right there, although I was able to get mine to barely pass with a chip when I pre-tested for fun.
