Old 02-02-2011   #21
Default Re: FX3 Shocks
Originally Posted by RedRiderZR1 View Post
99k
Others may argue but 100k on those shocks and IMHO its time to replace them. Do you see any oily fluid stains on the shock bodies. I beleive max life on a Bilstein is about 75K
Old 02-02-2011   #22
PhillipsLT5
PhillipsLT5's Avatar
Car has been sitting for some time, so not sure what it is.
Flat spots on tires?
Old 02-02-2011   #23
Another great Guess Phil
Old 02-02-2011   #24
RedRiderZR1
RedRiderZR1's Avatar
Flat spots on tires was my first thought before I even started the car to drive it. So I expected a possible rough ride. But the clunking coming from the front end over speed bumps and changing the shocks to the hardest setting pretty much stopped it (but not completely). So tires may be some of it I'm guessing. But something is loose up there. Like I mentioned, ride seems a bit spongy as well.
But this is all guess work. Until I can get it on a lift and see whats going on up there, I'm shooting in the dark. But just find it odd that changing the shock setting gets rid of it. But I will have to look at the tires and balancing as well.
Hopefully tomorrow.
Thanks.
Greg
1990 Bright Red ZR1 #41
ZR-1 Net Registry Founding Member #415
RedRiderZR1 is offline   Reply With Quote
Old 02-02-2011   #25
secondchance
RedRider,
My guess based on experience is;
1. Shaking most likely is from either flat spot or tires being not balanced. Also,severely wornout "A' arm bushings can induce shaking.
2. Clunking noise, most likely, is from worn out bushings.
3. At 99k, it is time for new shocks.
Just my thoughts.
Old 02-02-2011   #26
PhillipsLT5
Get tires road force tested
Old 02-02-2011   #27
All above are great suggestions. Id start with the tires the first as they are the easiest and move on from there. GC
Old 02-03-2011   #28
RedRiderZR1
Road force tested. Never heard of that before. Looked it up, that would definitely be a good thing to check out. Will look into that. All great ideas and I will check them all out. Thanks so much for all of your ideas. Gives me a good list of things to check out.
Greg
Old 02-03-2011   #29
Lots of great folks here who are always happy to help. Post up what you find to help the next guy out
Old 02-03-2011   #30
RedRiderZR1
Definitely will do that.
