12-28-2010 | #21 |
Re: Some "Dynomite" Heads!
If y'all are interested...I'll be happy to share w/ you where the "quicksand" is and how you might avoid having to pay big bucks to a welder when you have an "oops" moment...
Course, going it alone has it's own mystery and the excitement of "discovery" awaits; something to be said for that, I recon! Well...just a thought P.
12-28-2010 | #22 | |
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
12-28-2010 | #23 |
if I recall Jerry has some heads that are scrap.....do what Mercury MArine did, section the heads to find the weak spots.....would be cool for an article for HOB or video clip.
Just a thought
12-28-2010 | #24 |
I'm gonna cut those heads up in single cylinder chunks, with the cam cover installed, have 'em signed by Bob Hall, Pete P., and some other famous members and sell 'em for about a zillion bucks each so I can retire.
Seriously, it takes quite a few sections to see everything that is of concern for full boogie head porting.
12-28-2010 | #25 |
Sectioning the LT5 heads...Sounds like a winter project coming on!
I have a friend of mine that sends stuff out to a head repair outfit - that often sections heads (not LT5 heads) to make repairs. I'll see about sectioning mine and keep y'all posted. Also, I might need to borrow a stock (un-touched) head to take some measurements from, and or maybe make a reference casting from. (I'll attempt to locate the approximate location of oil and water, relative to the stock ID. The actual dimensions of say my ports are the "intellectual property" of Pete, Bob G's and Marc Hs. I'll just say they are big, and as Marc H said once, "80% of the risk (of perforating the runner) is in the last 20% of the cutting. In the mean time, I'll get some measurements and do a diagram and post it, for anyone interested. P.
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 12-29-2010 at 06:53 AM. |
12-30-2010 | #26 | |
Thanks for the compliment Jerry,i'll start cutting my heads to sell for zillions LocoBob i see your having some fun,very nice work There will be some fast Z's at BG next year (5 months) Pete
01-05-2011 | #27 |
Thanks Pete, wish I could do BG this year but its not in the cards, be fun to see what you FBI boys have been busy cooking up.
01-05-2011 | #28 |
Doing a little clean up in the bowl area with a sanding drum.
Here you can still see some of the casting imperfections. The unworked (grey area) to the side of the valve guide sticks out a good bit and forces an abrupt change in air direction just before the throat. I will be taking a good bit of this off and doing a lot of blending here. It is more pronounced on the primary side do to the angle of the port where as the secondary has a straighter shot "as cast". Another angle on this Looking down the primary you can see the "J" shape of the port near the bottom.
01-05-2011 | #29 |
okay, dumb Q's from the penut gallery. The Bowl is the area ( space ) starting the back side of the valve seat and going back up the head port(?) toward the I/H port(?)? The guide sticks into the bowl and into the air flow causing not good things? To "blend a Bowl" is to get rid of the rough casting finish, fix the protruding part of the guide, and some how 'straighten out' the air flow path from the I/H to the back side of the valve? I'm sorry to ask so many Q's. Thanks Bob. grasshopper
01-06-2011 | #30 | |
Not much you can do about the valve guide, you can trim it up a little and maybe contour it some. A few have cut it short but frankly I'm not sure that is a good idea, could lead to durability issues. The valve guide boss can be reduced in size and blended - by blending I mean smoothed and shaped. Straightening airflow is a key goal in most cases, it is not really possible in the bowl however. The air has to turn at the valve so basically you want to bias the port so that the air can make a gentle turn toward the center of the combustion chamber.
