#21 | |
![]() Join Date: Nov 2007
P. |
#22 |
![]() Join Date: Mar 2008
Well, the analog gauge doesn't work and I suspect that it became disconnected somehow. The codes show a H44 in the ECM which is a left O2 sensor fault. Started up the car and no service engine soon light on and the fan came on at 227 degrees. Took it out for a spin and the brakes started getting real hot. When we brought it back to the house, Carlos said that it acted like the emergency brake on on. Both the calipers on both front brakes were smoking as well as the brake pads. Got a small amount of coolant laying under the injector housing. Fix the analog gauge, put in new plug wires and check the underside of the plenum and see if we can locate the leakage.
