Old 07-29-2010   #21
Default Re: My first attempt at timing the LT5 camshafts
Kent Moore next to the repro:
Old 07-30-2010   #22
HAWAIIZR-1's Avatar
Nice work........almost as good as Carter's. Glad to see some tools will be available to folks that need them since the originals are expensive and hard to come by.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-30-2010   #23
HAWAIIZR-1's Avatar
A good point made by Jerry is to check to ensure you have the plug in the back of the cam after washing out if new or reground or otherwise serviced. I used Loctite 565 and tightened per the FSM. Mine cams came back without any plugs in the rear as they assumed I would wash out and replace anyway with new plugs. Thanks for mentioning Jerry!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-30-2010   #24
Jagdpanzer
Jagdpanzer's Avatar
Good tip Craig,
What size is the plug?
Old 07-30-2010   #25
HAWAIIZR-1's Avatar
Good tip Craig,
Phil,
Sorry, I owe you folks that info. I don't want to have anyone have to take the camshaft into the hardware store like I did to match it up. I had it wrapped in a towel and I think they thought I was toting a gun; I might have been carrying it like a soldier would.........that does not help.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-30-2010   #26
1/8" NPT, allen socket
http://jerrysgaskets.com/store2/root...roducts_id=440
Old 08-08-2010   #27
Polo-1
We found all the camshafts to be about 2-3 degrees off the ideal settings with factory pinning and needed to adjust all of them. All the camshafts were checked for timing again even if it was a little time consuming to remount the dial indicator on all 4, it was worth it to confirm.
Well, I guess I can join the "Timed the LT5 Camshafts Club" now.
Nice job
I found my factory pin time 120.75 and 105.5
I'm at 114 and 111 now (3hrs myself ) still more fun to go.
Old 08-08-2010   #28
HAWAIIZR-1's Avatar
Originally Posted by Polo-1 View Post
Nice job
Thanks Kevin. Wow, that is way off and definitely worth it to degree them in I see. I was not sure how much difference SGC Stage I cams would be with the change in lift and duration. Awesome that you could do all that by yourself and in record time.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 08-08-2010   #29
Polo-1
I think part of it is the Moldex crank has up to 3 degrees of play in it, with the kent moore tool in should be at 51* locked. I can rock it down to 48.5 up to 52 .
I checked my stock cranks, and had the same play
I have stage II intakes with stage I exhaust
Thats LH only...
Old 08-08-2010   #30
HAWAIIZR-1's Avatar
Okay, thanks for the explanation. I never thought of checking the play in the crank when locked down at the 51 degrees. Your motor is going to be a killer.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
