07-03-2010 | #21 | |
Re: Stage 1 Porting
Thanks for that input. I tried a little sample of a water-based cutting liquid - seemed to work OK. But, it was just a sample that soon ran out and the WD-40 was handy and seems to work just as well. I'm well aware of the aluminum porosity, but never thought much about oils like WD-40 penetrating the pores - leading to issues when welding (heads especially). Well...That tip is worth the Arty Johnson "Veddy Intorestink" award! P.
10-24-2010 | #22 |
Re: Stage 1 Porting
Still open to doing these
Stage I for $450 Stagr for $700
10-24-2010 | #23 |
Re: Stage 1 Porting
any dyno # for stage 1 and stage 2?
10-24-2010 | #24 |
Re: Stage 1 Porting
No and honestly i doubt there would be a large variance, I had planned on a dyno test but unfortunately I have bad rings.
My stage 1 is not much different than what many consider a full port job. If you are not port matching the heads you wouldn't want 36mm at the head face anyway, as there would be air turbulance from going from 36mm to 34mm(air hitting a wall) The biggest obstacle is the Inj bosses and I take them out.
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 10-24-2010 at 09:43 PM. |
10-26-2010 | #25 |
Re: Stage 1 Porting
Lee,
Give this some consideration, what's the turn around on a Stage I job? Rich
10-26-2010 | #26 |
Re: Stage 1 Porting
Pretty quick, I already have a set of IH ported, I would just need to do a Plenum which only takes a weekend to complete. The IHs are black, would need to be painted or PCd
If you do not want an exchange, meaning me porting your exact plenum and IH, I would say 3 weeks. I do have a meeting in CT from 11/9-11/12
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 10-26-2010 at 09:17 AM. |
11-24-2010 | #27 |
Re: Stage 1 Porting
Just an FYI, I will be trying out a Powdercoater and will let everyone know the results, he already has done a few sets of wheels for me......
Siamese port project starts soon and I will be pulling my ported intake off soon, will be available for core and $.
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 11-24-2010 at 08:55 PM. |
02-19-2011 | #28 |
Re: Stage 1 Porting
Shot of what I consider Stage I...these are coming off the 90 and will exchance for stock pair for $450, the $450 includes porting your plenum. These IHs are currently black.
02-20-2011 | #29 | |
Re: Stage 1 Porting
But, in comparison, there seems to be a bunch more meat and flow shaping to be cut around the secondary injector boss in the pic of your IH, no? And, it looks like there is little or no expansion of the IH outlet into the heads. I'm not critiquing, but just trying to get an idea of your "Stage-I specification". For some reason, this induction design vs. performance stuff always fascinates me, I recon. P.
02-20-2011 | #30 |
Re: Stage 1 Porting
Has anyone done any before/after dyno tests from just porting the Plenum and Injector Housings ?
