02-20-2010 | #21 | |||
Re: Noticed something interesting on my LT5...
So, things do happen that are not in accordance with the standard procedure. Quote:
02-20-2010 | #22 | |
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1 1989 ZR-1 #58 LT5 only 1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110 NCRS #3,182 SACC #2,420 Member Corvette Museum Corvette Forum: "ewjxn" 2009, 2010 Gathering Attendee |
02-20-2010 | #23 |
Well, I would hesitate going plural and counting this as a definite occurance, but after analyzing all the tags on the engine & crate and talking to GM personnel, it is the most likely circumstance. Fact remains, there are 2 engines with the same VIN, one is in the ZR-1, the other is a crate engine.
02-20-2010 | #24 | |
I guess I would ask what if that crate motor was sent back to BG what would the VIN stamp look like? What was the reason that the 405 LT5 was not installed in the correct ZR-1?
02-20-2010 | #25 | |||
02-20-2010 | #26 | |
Earlier you stated "The dealer received authorization and was shipped a new crate engine from GM stock (not Mercury)." So was the Same VIN derivation 405 LT5 (double vin) placed in this same stock source? What if a dealer was sent the 405 LT5 (double vin) as a warrantee replacement would they have XXXX out the Vin? Eric
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1 1989 ZR-1 #58 LT5 only 1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110 NCRS #3,182 SACC #2,420 Member Corvette Museum Corvette Forum: "ewjxn" 2009, 2010 Gathering Attendee Last edited by 1989ZR1#74; 02-20-2010 at 08:02 PM. |
02-20-2010 | #27 | |
I see where you are going with the next question regarding the GM engine stock source. All I can say is I don't know the answer. Same is true regarding whether the dealer would xxxx out the VIN. My guess is probably not. From what I understand, engine replacement was not a common ocurrence and this double VIN engine deal is probably a one-of-a-kind happening and that's how the VIN escaped intact on the 1st engine.
02-20-2010 | #28 | |
Not that #2299 will ever be judged or need to justify the stamp, I am very curious how two stamps in two places were wrong. I alway like to try and wrap my brain around these even though I have no skin in the #2299 game.
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1 1989 ZR-1 #58 LT5 only 1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110 NCRS #3,182 SACC #2,420 Member Corvette Museum Corvette Forum: "ewjxn" 2009, 2010 Gathering Attendee Last edited by 1989ZR1#74; 02-21-2010 at 12:02 AM. |
02-21-2010 | #29 | |||
There are several dates on this invoice, listed as follows (I'm not sure what the last two mean): INVOICE 5/24/90 PRICED 5/22/90 SHIPPED 5/24/90 EXP I/T 5/29/90 INT COM 5/29/90 So that means my car sat at the dealer for about 6 months before it was sold to the P.O. on 11/22/90. Since my block has a cast-in date of 3/7/90, that means the build date of my car should fall somewhere around March of '90 I would think. Are there any dates anywhere on the car itself that would give a clue as to what the build date was? Quote:
Who was this "Mary" person and what kind of moron starts a car at WOT??
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) |
02-26-2010 | #30 |
Any thoughts on the dates in my above post?
