#21 |
yes just ck the front.
#22 |
![]() Join Date: Jan 2004
I have 2 more sets left and then that's it
$155 shipped or pick up for 150 |
#23 |
Questions for those that have installed the Beam Plates:
Exactly where do you check the alignment? Do you jack the transmission towards the upper and right tunnel to get the alignment right? Do you tighten the back differential bolts and then check alignment? Or Are all the bolts just snug and then you check alignment? Do you use red or blue locktite on the threads? Thanks Guys |
#24 | |
The 1.77 in spacer should fit between the top of the driveline support to the underbody. The 1.1 in spacer should fit between the right side (passenger side) of the driveline support to the side wall. The driveline support is the "C" Frame. You might check that alignment spacing before you start the project to see where your alignment is now. Then just keep that alignment with the installation of the new C-Frame Plates. USE A TORQUE WRENCH ![]() The guys still have not told me what happens if you OVER torque the front or rear C-Frame bolts ![]() Last edited by Dynomite; 01-08-2012 at 09:41 PM. |
#25 |
I'm not just installing the beam plates, clutch too. I like the idea of checking the alignment before I start.
Thanks |
#26 | |
Then install bolts on the differential C-Frame Beam Plates (not tight). Tighten (Torque) front Beam Plate bolts (after you verify alignment) after you have the differential beam plate bolts installed but not tight. I would then tighten differential Beam Plate bolts last since there is no alignment to be done on differential ![]() Do you understand..... ![]() Last edited by Dynomite; 03-01-2010 at 08:52 PM. |
#27 | |
#28 |
#29 |
#30 |
No...you will see what you copied is different a bit than what I ended up with (organization only).....
![]() I could not even understand myself what I wrote for a while ![]() I write these essays to get feedback on my own sanity ![]() Last edited by Dynomite; 03-01-2010 at 09:35 PM. |
